Adding Passive Entry: How-to
this is the part in the door, not under the car. Tee ones under the truck for the rear fascia DID snap in.
Don't think I can see the pins on the other side, at least without removing the other plugs.
AND now I need to order new male pins, damaged one of them try to get it through the boot.
ETA: I decided to try and finish up and see how it went since I was like 90% done. I "re-jimmied" :p the male pin, finished the install and did the JSCAN changes. Well, what do ya know....everything works! Woohoo!
The male pins for the doors did seem to "set" in but didn't fully snap in like the ones for the rear fascia. 🤷‍♂️
I ordered some replacement pins, if it stops working I'm reasonably confident where the problem might lie since I re-crimped the one.w
What kind of programmer did you use and what bypass did you buy?
I used JSCAN, OBD Link MX+ OBD2, Exctool 12+8 Pin Security Bypass, links below. I think there are cheaper options but that's what I went with.
OBD
Security Bypass
I still haven't gotten around to messing with the connectors but passive entry still working.
If you've seen the original thread on adding passive entry, HERE, you are likely well aware of the issues with getting it to work on the newer trucks that didn’t come with it from the factory. This thread will walk you through getting it to work on the 5th gen DT’s (and the HD trucks) just as it does in a factory-equipped truck, without requiring a visit to the dealer or the addition of the sales code to your VIN.
The success of this has been a collective effort with contributions from many individuals and they all deserve thanks since a lot of time and effort went in to laying the groundwork for this, both on the 4th gens and the new 5th gens, as well as helping test and troubleshoot to make sure all aspects of the system functioned correctly before pushing this out.
Standard disclaimer…If you are going to do this yourself, you are assuming all responsibility in the event something breaks or goes wrong. Also, any parts you add related to this are likely not going to be covered under warranty in the event there is a problem down the road. That being said, the whole process is fairly straightforward if you have basic mechanical abilities and a little patience for dealing with the door panels and wiring. Just be careful and take your time.
Clicking links below will take you directly to the specific posts indicated:
Post #1: Basic list of parts/tools required
Post #2: Door panel and handle removal
Post #3: Carrier plate removal
Post #4: Making the BCM changes in AlfaOBD
Post #5: 2019 & 2020 Rear Antenna
Post #6: 2021 Rear Antenna
Post #7: Part numbers for handles, caps, clips, terminals & connector housings
Post #8: DIY Harnesses
Post #9: How-to for the HD trucks
Post #10: HD install continued
The following lists out what you will need to get this accomplished on a 1500. The HD trucks utilize a one piece handle and already have the wiring in place for the rear antenna. Specific part numbers are listed in post #7, and I will update the list with additional items as needed.
Factory PE Parts
- Door handles for proximity entry x2 (handles are the same on both sides on the 1500)
- Door Handle Cap, Right (specific to each side and passive entry as there is a magnet inside)
- Door Handle Cap, Left (specific to each side and passive entry as there is a magnet inside)
- Front Door Wiring, Right (must support passive entry, or you can just add the 2 wires needed utilizing info in this thread)
- Front Door Wiring, Left (must support passive entry, or you can just add the 2 wires needed utilizing info in this thread)
- Rear bumper passive entry antenna (The cheaper $8 antenna has been proven to work)
- Rear Bumper wiring harness (must support passive entry, or you can just add the 2 wires needed utilizing info in this thread)
AlfaOBD
- Android tablet or Windows PC
- AlfaOBD software for your tablet or PC
- OBD interface (MX/MX+ is used by many, but there are cheaper options that work)
- Security Gateway (SGW) bypass
Tools:
- Trim tools (not 100% necessary, but well worth it to not damage panels and/or clips. Plenty of options online or at most local parts stores)
- The elusive 10mm socket and your choice of ratchet/driver (a short extension will be handy also)
- 6mm socket for speakers (5mm for the HD)
- T20 torx for the HD panels
- T25 torx for the 1500 door handle cap (needs to be long enough to reach inside the hole in the door, about 4". May also be able to use a small flathead for this)
- T27 torx for the door latch
- Small flathead screwdriver (1/8)
- Needle nose pliers
- Tape (for holding up the window once it’s unbolted. Decide what you feel comfortable using)
Important note: Passive entry will function with the addition of just the driver’s side handle (only activating from that handle obviously) and the settings configured in the BCM. However, if you choose to not add all pieces, fobik safe will not function as intended and it will trigger fault codes in the RF Hub. This means that there is a slight chance you could induce a condition that would allow the fob to be locked in the vehicle and will not be alerted. If you install both handles, and the 5th antenna, everything functions as intended and you will get an alert should you accidentally leave a fob inside the cab and attempt to lock the doors.
So, I've got a 2021 Rebel that came with the passive entry, but recently the driver's side slowly stopped working and has completely stopped working (proximity sensor & the button). Do I need to replace the entire handle? Just components within the handle? Any help/guidance would be much appreciated as I can't seem to get a straight answer anywhere else (and the dealership wants $175 just to look at it even though it may be under warrantee).
Thank you in advance!
I'm not 100% sure what the problem would be but I'm pretty sure none of the components in the handle can be replaced, you would need to replace the whole handle but it's really easy to do and they are not that expensive online. One question though, does the passenger side still work?
Working on this mod for my 2021 big horn. Currently waiting on a Rock Auto order before I can wrap up though :/
2 things that I got hung up on w/ this install:
1. It was not apparent to me the model and quantity of little rubber wire insulators required for the 2021 rear antenna install. I ordered one extra on everything but thought I only needed 2 insulators so ordered 3. Those things are needed at both the rear facia plug *and* the antenna connector. To clarify, you need 4. They are the same on both ends of the wire.
2. The door handle end caps. Passenger door install went fine but on the driver door reinstall I could not get the screw to bite and thus the end cap (and door lock) was insecure. The threads on the piece of metal the screw goes into are shot. Unfortunately, the only way to replace this metal piece is to disassemble the door again. Also, you can't buy just this part; you must ~replace~ buy the whole plastic bracket in the door. Fortunately the metal piece is the same in both sides. I bought the cheaper passenger side to swap the metal piece out of:
EDIT: Get the correct side. This piece was stripped out again by the time I was able to remove it from the bracket. Awaiting a 2nd Rock Auto order :(
I replied to your PM, but just to remind everyone else who may read this….don’t freak out if your Uconnect menus and settings seem all messed up for a while after disconnecting the battery or making changes in the bcm, you didn’t break anything. If you have a navigation system in your truck it may take several ignition cycles or overnight for everything to return to normal. The non-nav systems seem to reset much quicker.
Hi, I’m not sure if you can help me, but I have a 2020 Ram 1500 Bighorn. I installed the passive entry system and followed the instructions carefully. While the passive entry works great, I noticed that both the check engine light and the stability control light are now on. Did I do sumthing wrong?
Pull the check engine light codes and see what it says
Thanks for the response; yes, I got it figured out. I read that sometimes if you disconnect your battery, the light will come on. So it said to go for a ride, and it should shut off, so I went for a drive, and it went away. Everything has been good since.
For the rear harness, where tf do you get the parts. I found some at mouser but the wire seals? I aint paying 10 bucks for one little rubber nipple.
Does anyone want to make me the rear harness? I’ll gladly pay for your time.
Nvm. Found it all
Ok. I need some info. Ive combed through this thread several times but with 63 pages, I’m sure I missed it.
I have a 1500. I bought the antenna and the connector/terminals to build the harness but couldnt find specific information to installing it.
Where (not how, I read ziptie, screw, etc) to mount the antenna? Should it be off to the side below the tail light? Or in the middle?
Where is the connector to pin the harness?
1500 what? Anyway, mine slipped up in a little spot behind the license plate from the backside under the truck. Then I used zip ties to secure.
If anybody doesn’t want to spend the money for the entire door harnesses and rear facia harness, and doesn’t feel like building the add on harnesses with the parts, let me know and I can build them for you-
Are you still making harnesses? Is you are how much
  • Back
