Rebel GT Exhaust question
I did 2 videos awhile back on my 2023 Laramie from the factory it had non GT Muffler with GT Resonators.
Later I put on the complete GT Exhaust.
Thanks! That sounds really good and more of what I’m after. How as it in the cabin? Did you notice it being any louder than the average DT 1500 that I’d assume has non GT resonators and muffler?
Thanks for the info, appreciate it.
The cabin sounds fine it's not obnoxious at all. Yes it sounds throatier than the standard DT Hemi and worth it.
The muffler and drivers side resonator are connected as 1 long piece.
The passenger side resonator is on a separate pipe that slips into the Y after the muffler.
My 2023 Laramie Sport came with G/T resonators so I needed the muffler and drivers side resonator assembly part # 68517364AA.
The G/T Left Resonator has this number stamped on it C-9408-L the right C-9408-R the G/T muffler is stamped C-9396.
Thanks for the info, I appreciate it. I need to do a little more homework before committing!
It's the Mopar Cat Back which is made by Borla(S-Type). You can order it from you local dealer or online.
A Borla S-Type Catback is $1200. The Mopar kit is close to $2K. Go with the Borla.
I do not think they are these same, and I think the Borla sounds SIGNIFICANTLY better, as I have one and love it more than anything I've ever heard for these trucks.
The 2026 5.7 Hemi is going to include the GT exhaust standard along with the 33 gallon tank. Too bad they aren't bumping up the hp to at least 400.
This is confirmed by Mopar tech dept and Borla..the Mopar 77072520AA Catback is made by Borla and is designed to be between the Type-S and Atak versions of Borla mufflers soundwise.
The Mopar catback is a bit deeper and louder overall than the G/T exhaust..some of this is due to the 2.5" Mopar vs 2.25" G/T tailpipes.
The G/T exhaust is going to sound less aggressive since it uses a 1 in 1 out muffler with a Y behind the muffler to split the pipes to be dual.
