I wonder if that is only with a certain package, my truck doesn't seem to have a button there. It does have the lights in the bed and a button on the inside of the bed drivers side rear near the tailgate and the outlet but that button only seems to turn off and on the bed lights.
Awesome thank you.
I messed with the truck a little today, and ended up with a few questions and so far am only on page 61 of this thread in my attempt to read all of it.
I can't seem to find a way to stop the bed lights, the light by the brake light on top, and the side mirror lights that point at the ground to not light up every time I open or shut a door. The button in the bed seems to turn the bed lights on or off, but they always come back on with a door opening or closing. THese lights, seem to work independently from the inside cab lights that can be set to off so they don't come on when a door is opened. Is there a way to stop those exterior lights mentioned above from coming on?
The "auto" feature for the climate control, does that only control the seats and steering wheel heaters?
The turbo coolers or whatever they are that run for 20 minutes or so after the truck is shut off, 1st is that what the slight buzzing/humming is? If so, if they're built to run to cool something down, why do they run for 20 minutes plus after any starting and stopping of the engine? It can be 30 degrees f outside, I start the truck and move it 2 feet and shut it back off in under a minute, something actually got warm enough to warrant these things running for the next 20 minutes? That just seems weird to me, and if it's correct apparently it has nothing to do with the temp of anything? Just looking for verification that it's designed to operate that way.
