accidentalyEV
- May 9, 2024
Has Ram solved this issue for anyone? After 5 years of ownership this started happening to my passenger rear door. Is there a TSB?? My dealership doesn't seem to be aware of the fix....Hi all. I bought my 2019 Ram 1500 Limited used last September, with 18K miles on it. We have pretty cold days up here in Maine, and pretty much from the time the daily temps went below freezing I have not been able to reliably open my rear doors from the outside. Basically, pull the outside door handle and it doesn't budge.
When this first started happening I tugged the left rear door handle a bit too hard, and apparently snapped a cable in the door. (I have been waiting since the end of November for the part, dealer says it's backordered and unavailable?).
When the right rear door handle didn't budge budge I was a bit gentler with it, and opened the door from the inside, only to find that when I shut the door it wouldn't latch. For grins I pushed in and pulled out the lock button manually on that door, and found that the door latched, but then found that the door could no longer be opened from the inside, either.
Great, now I have two rear doors that are unusable. I brought the truck back to the dealer last week for the right rear door issue. They told me that this that and the other thing were misaligned and that they fixed it and it works perfectly now. So I picked the truck up, and stopped at the grocery store on the way home. The right rear door in fact opened just fine, but when I shut it it wouldn't latch again. I immediately called the dealer, and of course he said, gee, we've never ever seen this kind of issue with these trucks. Note that I have never had an issue with the front door handles.
Again, these rear door issues seem to happen only when the temperature is below 30, suggesting that water is trapped somewhere in the handle/lock/latch mechanism and frozen. It's hard for me to believe that I am the only one encountering this, on both rear doors. Has anyone else had this issue?
Thank you for bringing this to our attention @DPhillips78. Our team has responded and look forward assisting you!Has Ram solved this issue for anyone? After 5 years of ownership this started happening to my passenger rear door. Is there a TSB?? My dealership doesn't seem to be aware of the fix....
I've just sent a message to @RamCares
Once i got it all the way put it worked perfectly. I still have no idea wth happened but its back to function, so ill take my merry truckmas a smileIf the door latch was tripped into the latched position which is what it appears to be just rotate the latch around to the opened position.
Thats shows as a different language for me..so in case its that way for others![]()
Жизнь барана в России, продолжение
Мальчик после зимней мойки переживает о том, что двери не откроются утром. Мужик переживает о том, что двери не закроются🤣 Так случилось и со мной- открыл дверь и замок остался в открытом положении,…www.drive2.ru
Hi @jcross15!2021 Laramie 1500.... have the same rear passenger door issue. Dealer quoted $800 to fix!! I just bought this truck.... @RamCares how about some help with this KNOWN ISSUE with these trucks!!
Hi @Gren71,Once i got it all the way put it worked perfectly. I still have no idea wth happened but its back to function, so ill take my merry truckmas a smileIf the door latch was tripped into the latched position which is what it appears to be just rotate the latch around to the opened position.
Here is a thread of what I went through when this just happened to me a week or so ago. After completely disassembling the door it seems like it was probably related to a temperature / freezing issue. I lubricated the hell out of all of the moving components before putting it back together and even in the recent couple of days with cold temperatures, I haven’t had the issue reoccurred once.
I sincerely hope this works for you. I did basically exactly what you did and my handle froze a couple weeks ago with cold weather. fortunately it worked fine after thawing (I had enough with this and started to dig in myself. Dealers here in Omaha, NE should they are like 2 weeks backed up or something like that. Anyways like I said in my post above, never experience this issue until I moved to NE.
So after watching number of videos and blah blah blah. I found this guy that was installing the passive entry, thank you, whoever you are and sorry for copying your video
Yes, you do need to remove the entire inter panel and disconnect the window. It is pretty easy and do not force anything. My door latch that was freezing was only my passenger rear. All the other doors were fine.
His instructions are pretty much the same for the rear doors. Just I did not disconnect the wiring harness to remove the panel totally out of the door. So my problem wasn't the cable freezing. It was what the cable was attached to inside the latch itself.
I lubed, freeze proof grease, WD40, Waterproof WD40/Silone, everything into the blue circle areas on the latch. (do not put lube in the blue circles in the pictures where the bolts go into btw)
On the latch itself it has a black cover. Just pop it off. You can see the cable where it is attached too. That linkage was stiff, after lubing it and actuating it a few times it loosen up.
View attachment 196212View attachment 196212View attachment 196213 Just reserve order the process and make sure you recheck the black cover again. Because I forgot to do it and now need to reopen everything again... arrrrggg.. So tonight/tomorrow it suppose to drop temps again. So hopefully this worked.
I sincerely hope this works for you. I did basically exactly what you did and my handle froze a couple weeks ago with cold weather. fortunately it worked fine after thawing () and now i just child safety locked that side and have my kids both get in from the drivers side.
Yep, unfortunately it did. And i also noticed the same…that opening from the inside it works fine. The child lock just builds the habbit for my youngest to get in/out the other side. I actually haven’t checked if its working in a couple weeks..im hoping to keep it out of my mind until the spring and hope it works regularly then. The whole sex panther probability isn’t something I want to mess with when its cold.Damn..... so yours froze again after greasing and all that? I also noticed that if open from the inside it latches just fine.
Also hoping a tsb or something comes out by then.
