I didn’t replace anything. Ill end up having the dealership do it under my warranty at some point. It doesn’t seem hard to replace after having it apart, but i wasnt able to dial in on the exact component that was failing…so either I replace all of the pieces or i run the risk of having to disassemble the door multiple times while troubleshooting. Which is what id rather have the dealership do so if anything else breaks its on them and not me.ahhhh crap.... did you replace the cable? or anything else? Looks like replacing the cable is pretty easy compare to replacing the latch mechanism. I'll repost tomorrow morning ish.
I opened my passenger side, rear door like any other day and then when I went to close it, the lock is stuck in the locked position. Thankfully, I’m at home and in my driveway but now I can’t secure my vehicle…
I didn’t slam the door so it’s not forced into its position hopefully.
I have the door mostly assembled thinking maybe something just came disconnected
but I’m to the point where I’m at the interior panel and I can’t get it off without removing the glass. And I’m feeling like I’m hitting the place where I’m out of my depth.
Does anyone know a trick or away to manually cause...
Heres my thread from December. Just so you know your not alone in this all.
