2025 REBEL X Build Thread
VICE design
Trusted RAM Truck Adventure Gear
5thGenRams Vendor
Canada
Stoked to say we finally received our 2025 Rebel X that we ordered last summer. Was worth the wait - this is one sweet truck. I drove it strait to our shop and started to take it apart. Despite a similar appearance to previous years - there's a ton of changes, which means most parts we have won't transfer over, but I love a new challenge and can not wait to start designing new products geared for those who want to see more of the world or simply want a unique look.
Here's the truck - wanted to order one with most of the bells and whistles so we can test everything.
-Rebel X 10th Anniversary Edition
-Mohave Sand :love:
-Level II Equipment Group
-Advanced Safety Group II
-Ram Tow Assist
How it Started:
Edit: HOW ITS GOING
I'm excited to get this out on the backroads, but before I do, it need a winch and some off-road lighting so I'm starting on that today. Excited to share the progress here.
What upgrades would you like to see?
- Quinton
www.vicedesign.ca
-Mohave Sand :love:
-Ram Tow Assist
- Quinton
www.vicedesign.ca
that truck in that color would look good with a fancy roll bar and a lightbar on top in Black
pre runner style bumpers!
Chase light mounts (something like GodzMFG)
Rock sliders!
Skids!
Rear differential skid!
The sky is the limit…
Thanks for the feedback!
Before I added lights I wanted to lay the foundation for powering them. Designed up a bracket to hold my Auxbeam AR800 - an 8 button solid state relay system that will power my accessories from a simple button panel I'll mount inside the cab. Quote happy how this first prototype fit.. It bolts directly to existing hardware and It has slots to zip tie all the accessory wires so they will have adequate strain relief and will keep everything secure.
Sheetmetal CAD:
Cut, cleaned and formed into shape with the Auxbeam Switch Panel installed:
And Installed in the engine bay. The black bumpers under the logo isolate the bracket and damp engine bay vibrations. New design also allows for easier battery replacement.
The existing cab bracket I have for the 19-24 trucks will port right over. I'll get this powder coated black and wired up after the weekend.
Often if you get your truck stuck, the easiest way out is the way you went in. I added some recovery hooks to the rear of the truck using our Mounting Kit. The hooks themselves are the same as the Front of DT trucks which can be purchased from MOPAR or there are some aftermarket brands available out there as well.
Ordered some Baja Designs LP6 Pro's for the front, so set off designing a set of bolt on brackets.
A pair of Rubber isolators mount between the bumper and the bracket to damp vibrations, allowing a cleaner light beam when mobbing backroads.
Brackets attach securely to existing hardware in the top of the bumper, and are powder coated with the same finish for a stealthy look.
Mounted - LP6 lights should be here this week :)
Im assuming this kit wont work for the left side mounted center bed step? If not, do you have a kit that just does the right side?
Correct, the Multifunction Tailgate step is not compatible as it shares the same area. We do sell the bracket for the Rear Passenger side
You'll need the Front Left (drivers side) recovery hook. Part number is in the product description
same concept as dark dunes' (which now went under) and i can already see the same issues happening. the rubber isolators are not going to help much because that's not why the lights wobble when bombing down rough terrains. i had the same issue when i was running LP6 on the same style brackets. I also came up with the solution and was gonna make these things but i sold the whole thing to my customer. solution is to add a support that triangulate the front of the mount. Thicker materials may help too.
Thanks for your feedback. These are a prototype and the first version had no isolators. The difference between the two versions is substantial. Always looking to improve so I will look into adding a gusset to help with deflection due to heavier lights.
yes sir lol
i was gonna make and sell them since i found and solved the problem but i just gave it for free.
now i expect a 10% payment for every one sold :p:p:ROFLMAO:
Vice,
Just want to be sure that this will fit my 2025, as the listing says 2019-2024....
Vice,
Yes it will. Same one is installed on my '25. I'll update the website thanks for the heads up!
Sorry haven't posted lately, but the work hasn't stopped! I invested in a 3d scanner to speed up development and get the fit and finish that much better. Also have been steaming along on the one that everyone has been emailing me about - A Hidden Winch Mounting System. Here's some pics to bring you up to speed.
Full system. 100% bolt on. Installs without removing the bumper.
Side profile. Skid away, nothing to get hung up on here.
Today I got to build all the components and fit it up to our truck. Here's the bolt on bumper section that also houses our SL-8 lightbars. As a bonus you can also run an OEM style mesh over the opening. Or both...
Easy to access jack point.
Time to pull it off, Finish welding it up, and color match it to the bumper.
Update on the Bumper Mount Light brackets - after 10 different revisions, I'm now super happy with how they fit and how sturdy they are. The front "bracing" bracket is on slots so you can effectively pre-load the bracket to account for the weight of heavier Lights like the LP6. The isolators have been moved more outwards which damp vibrations further while protecting the surface they sit on. And of course powdercoated to match the bumper so they blend right in.
You can get your set here:
OEM+ LED Bumper Light Mounting Brackets | 2025 RAM Rebel & RHO
How long have you been using the Auxbeam AR-800? Any issues with it?
This one since January, but have been using the single color 8 gang in my other truck for 5 years without issue. If you go with the Auxbeam I only recommend the ones that have the diecast aluminum base with solid state relays (these are the only ones that are compatible with out mounting kits). Avoid the cheap 6 gang units with plastic housings and exposed relays.
Also if powering the Baja Design LP6 or LP9 lights, you need to run their lockout upfitter harness. Essentially it only lets you power a low beam OR high beam. as powering both can damage the lights. The auxbeam in this case only works as a switch, as all the current goes through the Baja Harness.
The mounting kit is done and here's how it fits on the Hurricane platform:
So awesome seeing so much progress! I picked up a Rebel X in the same color and pretty much same options a couple months ago and am stoked you guys are making so many products already. Excited to start purchasing parts in the near future!
Put together an installation video that goes into more detail on the Hidden Winch Mount and how simply it installs. Thanks for watching 🍿
  • Like
Reactions: TCP
