2025 Ram 1500 Current Owners - Discussion, Feedback, and Problems
Yes, mine does the same but I also had the issue in my 2023.
Yup, been trying to figure this out. One would think it would be the same volume as music you are streaming but nope.
I think, it somehow only comes through one speaker (drivers dash) when it gets quiet. It may have something to do with the surround sound programming. I suppose I could test it by turning off surround sound but, I do enjoy the surround sound.
I have surround sound off
Another issue I've noticed is when setting up my dash screen (the left, right, upper right, lower right) information to display, it does not give me an option for the "right" side of the screen. On my last truck, I had my distance to empty setup to be right there, and I wanted it on this new 2025 as well. But no option to even select the "right" side of the screen. Anyone else have this issue or even notice? This is issue number 3 with not even 100 miles on the truck yet lol.
My 2019 Big Horn didn’t have a right side and my 2025 doesn’t… maybe, everyone with the 7” screen (on 2025s) has the Big Horn version because they went full digital for the premium dash.
stage 1 of the trip is complete. Went to Sequoia National Park and back home the same day. Today we are heading for AZ to exercise some 2A rights.
only thing I noticed is battery voltage is a lot lower than I've seen. high 12's to low 13's. stayed consistently low the whole trip, checked voltage with key on - eng off, mid 12's... I am concerned about that.
it normal volts when you use your truck and don't do little stuff to keep them up.Is that mpg unloaded.My truck always had a full tank and i have a lot weight in my bed . I am at 13 mpg 93 octane. In stop go traffic still surging.
Nothing turns on on approach for my limited. I have proximity wake up on. The animation and ram log turn on when I unlock. Is there another setting? Am I missing something?
go to screen setting lights it in there
Hm...that's weird. My 2019, 2021, 2023 all had that option. It's just blank on my 2025 and it looks like something is missing. I'm adding it to my growing list of things for my Friday (tomorrow) dealer trip...smh
What Trims did you have those years?
I just let it
Good tip. But, man, it’s ridiculous to need these shenanig
it will work mine doesn't sometimes . unlock and lock walk in house and back out that wakes up system to see if they work .
I've tried that multiple times. No luck. It's activated in the settings but doesn't respond.
your having dash setup issues my post was for someone with approach light problem .I talk on few threads and sometimes they post on wrong one.
Things are a little crazy with these new ones . You gotta use same key fob cause setting can change with fobs and profiles . Every time you start truck must double hit profile.
Ya, I only use the one key fob. My other one is stored away in a cabinet. I'm thinking it's just a programming issue or something.
  • dlee
