Just got my truck. Let's see how this goes. I'll do a cold start tomorrow and see how it sounds/drives. So far so good though.
fingers crossed
sport mode helps with stumbling below 2000 rpm slow driving but then it won't shift 2800 rpm higher these new ones are faster but i don't drive that way anyone else having slow drive in auto mode ****ty shifting the update fixed cold start misfires and before update if you just touched gas pedal a hair in park engine would die don't do that anymore after update again it is quiet smooth faster but normal driving suck it stumbles thru shifting can't wait for woo ram cold start info
Are you talking about the studs on the end of the fuse box, that are “ground bolts”. I thought that was a fuse panel of its own?opps out of the 8 ground wires just check them pull box off
Mines been good (knock on woodeveryone turn stop start feature off it will kill engine and battery volt s mine sit at 14 to 14.5 with that auto stop start on low 13 brahmajoe how is your truck been running
 )aside from waiting for a shifting update. Yours?
)aside from waiting for a shifting update. Yours?Picky picky… those UAW workers need araise…that's crazy check cap for brake fluid again i check ed all fuses underhood under dash half of mine were not pushed in and next to fuse box underhand hood is a place where 8 ground wire are i don't have a wire and the bolt for that on was sitting lose not installed siting on two ground i screw it on to the empty ground bolt where it belonged
