It's rumored that the Hemi had issues with idling causing the lifters to fail due to sufficient lubrication at idle. I would hope the Hurricane will be better
Current 2022 Hemi
That rumor has been debunked long agoIt's rumored that the Hemi had issues with idling causing the lifters to fail due to sufficient lubrication at idle. I would hope the Hurricane will be better
Maybe the changes were an attempt to get better oiling to the lifters to prevent failure. Thinner oil pumps easier and will get into the lifters fasterNobody will ever convince me that the ever changing oil specs on the 5.7 engine didn't have something to do with it. They made those engines for 21 years and only updated it once in 2009, but if you go through all the yearly manuals you see 3 or 4 different oil specs. CLEARLY this was for EPA certification and not engine longevity. First thing I did to mine was dump the 0W20 and go to 5W30 and all the ticking and valvetrain noise disappeared immediately. I probably could have gone 5W40 for summer use and it would have made the old fashioned 5.7 even happier.
I suspect the increased film strength of the higher viscosity oil plays a larger part in preventing failure.Maybe the changes were an attempt to get better oiling to the lifters to prevent failure. Thinner oil pumps easier and will get into the lifters faster
As long as it can get there. Tighter clearances negate benefit of high viscosity on modern engines, if the clearances are too tight for the oil to get thereI suspect the increased film strength of the higher viscosity oil plays a larger part in preventing failure.
The clearances aren't that much tighter that would reduce the oil flow to zero.As long as it can get there. Tighter clearances negate benefit of high viscosity on modern engines, if the clearances are too tight for the oil to get there
Not bad for a Platinum, compared to what Ram and GM are charging...BTW, that 2024 F150 MSRP was $81K![]()
It's all speculation at this point since nothing has ever been scientifically proven to be the culprit. I'd still take the higher film strength oil at a slightly reduced flow rate. Why do you think the hellcats run 0w-40? Higher bearing loads need higher film strength. I understand the hellcats have higher flow oil pumps, but the 5.7 oil pump is still capable of providing sufficient lubrication. In my opinion, the oil pump isn't the real issue, it's probably the substandard material in the cam and lifter roller issues. Putting a hellcat oil pump in a 5.7 is a bandaid fix, not a root cause fix.You already have people saying the issues is oil starvation, now you want to increase the likelihood of less oil flow?
Well it didn't help the Ecoboost apparently at 18.5 MPG vrs my 20 MPG W/O a hybrid system, in the same 300 mile stretch.If you were in bumper to bumper traffic, your Hemi doesn’t get 20mpg no matter how much you want to lie to yourself.
Putting a hellcat oil pump in a 5.7 also causes check engine light for high oil pressure. Meaning the engines aren't built with same tolerances, or the oil passages in hellcat are bigger.It's all speculation at this point since nothing has ever been scientifically proven to be the culprit. I'd still take the higher film strength oil at a slightly reduced flow rate. Why do you think the hellcats run 0w-40? Higher bearing loads need higher film strength. I understand the hellcats have higher flow oil pumps, but the 5.7 oil pump is still capable of providing sufficient lubrication. In my opinion, the oil pump isn't the real issue, it's probably the substandard material in the cam and lifter roller issues. Putting a hellcat oil pump in a 5.7 is a bandaid fix, not a root cause fix.
Which is why a 0w-40 is spec'd for the hellcatObviously.
