mhb1638
Thank you guys for the explanations
Is that ahead of the air filter in the intake system? What's its purpose? Maybe catches biggest items before filter like moths and dandelion seeds??? Sure looks restrictive.
Would it be required to be in place when having state emissions testing done at license time? In early inspection days, the Oregon DEQ inspection use to check fuel filler neck for tampered "unleaded only" restrictor and use mirror for catalytic converter inspection under vehicle. I guess today if vehicle computer is happy with emission readings, the inspection should pass.Most of the comments tend toward charcoal filter to catch fuel vapors after the engine is shut off...
Installed:
Bed Extender Handles and Pins
OEM Step Side Kit
Oil Catch Can
Its a Linesracing from Amazon. It came scratched on the top. So I just polished it up a little. No problem with hardware. It mounted up fine. You just have check the orientation of the baffling dip leg.Is that the kyostar can off of ebay? If so, how did you find the install?
A couple of my parts seemed backwards... had to dig some nuts/washers out of the parts bit to get it fit correctly.
Changed the upper bed lights to LED. Installed my Backflip MX4.
What LED lights did you use for the upper lights??
"LUYED 2 X 1550 Lumens Extremely Bright Error Free 921 912 W16W 3030 24-EX Chipsets LED Bulbs Used For Backup Reverse Lights, Xenon White"
From Amazon. No error codes as of yet.
You have a link to those nerf bars?Just installed 2" leveling kit, N-Fab Nerf Bars and 15% tint. Loving the truck so far!!
I have these and a red flasher LED waiting for me to install."LUYED 2 X 1550 Lumens Extremely Bright Error Free 921 912 W16W 3030 24-EX Chipsets LED Bulbs Used For Backup Reverse Lights, Xenon White"
tonneau cover looking good, is it water tight??I installed the mopar mud flaps, rear fender well liners, mopar hard tri fold tonneau cover and 2 battery powered led light strips under rails in bed.
Its post air filter. And I tried to blow air through it and yes it's very restrictive. I just used a screwdriver to pop the super flimsy plastic rivets holding it on, it's like they wanted you to remove it easily. Good for another 1mpg for sure or another 10 hp with the Pulsar tunerIs that ahead of the air filter in the intake system? What's its purpose? Maybe catches biggest items before filter like moths and dandelion seeds??? Sure looks restrictive.
