Rebel leveling kit
wpghemi
Hi Guys, new to the forum, what are guys running for leveling kits on these trucks?
I don't want anything crazy. I was thinking 2"
Can that be used on both air and coil suspension? Im new here and would like to do the same thing as wpghemi.
"not for use on air suspension trucks.." click the link ;-)
Im in Canada so I don't have the air.
I was worried the spacers wouldn't work with the rebel being higher already.
In Wpg as well, went with the Motofab 2.5" top hat spacer with the UCA's listed above... it's cheaper to get them seperate on Amazon. I wouldn't recommend using the factory UCA, the ball joint angle on a leveled Rebel isn't pretty.
Congrats on your new Rebel.
What size of tires are you running?
Thanks I love it! my business partner and I ordered two matching rebel's we had to wait for the rambox. mines white and his is granite
For this year, just stock wheels and tires... might switch to 35's in spring.
Hi there. I have a rebel also and want to level it. Any chance you can post a link to the correct UCAs on Amazon you referred? Assume they can be used with either RC or Motofab 2.5” spacers?
I went with the Moto Fab 2" top hat spacers and the Mopar upper control arms from their 2" lift kit on my Rebel. Running Nitto Terra Grappler G2's in 295/70-18, basically a 34x11.5, for tires. Install next week, will post pic's when done.
UCA's on Amazon
They can be used for any lift up to 6". Very happy with them.
I worked with my installer for quite a while to get the right level kit and we kept coming back to the ready lift. After calling ready lift I was sold. Will be installed Tuesday. standard suspension on my rig, no air ride to deal with.
Just finished up the 2” Readylift leveling kit with the upper control arms. #66-1921. Took me 1.5 hours to do so not bad at all. Front measures 40” from ground to top of wheel arch and 40.5” in the rear. Goes in to the dealer for new rims and tires on Thursday.
Just got the ready lift leveling kit with control arms installed yesterday. Modest change in appearance but I feel it improves the stance considerably. D6B2D846-48CD-4E1E-BFBD-9AD771C5ED6A.jpeg
Just got the ready lift leveling kit with control arms installed yesterday. Modest change in appearance but I feel it improves the stance considerably. View attachment 13801
You're right, it isn't going to "wow" like a 6" lift with 37" tires... but it really gives the Rebel a more "off road" stance that they should have designed onto the Rebel package.
For the Mopar uca's from the lift kit
Where would I get the part numbers? Or do you have a link?
I want to do the exact set up with the motofabs but I can't find just the uca's
