Can that be used on both air and coil suspension? Im new here and would like to do the same thing as wpghemi.
In Wpg as well, went with the Motofab 2.5" top hat spacer with the UCA's listed above... it's cheaper to get them seperate on Amazon. I wouldn't recommend using the factory UCA, the ball joint angle on a leveled Rebel isn't pretty.Im in Canada so I don't have the air.
I was worried the spacers wouldn't work with the rebel being higher already.
What size of tires are you running?In Wpg as well, went with the Motofab 2.5" top hat spacer with the UCA's listed above... it's cheaper to get them seperate on Amazon. I wouldn't recommend using the factory UCA, the ball joint angle on a leveled Rebel isn't pretty.
Congrats on your new Rebel.
Hi there. I have a rebel also and want to level it. Any chance you can post a link to the correct UCAs on Amazon you referred? Assume they can be used with either RC or Motofab 2.5” spacers?What size of tires are you running?
Thanks I love it! my business partner and I ordered two matching rebel's we had to wait for the rambox. mines white and his is granite
What is the leveling for the bottom picture? What size tires/wheels?
I have them on my Rebel... I speak from first hand knowledge.I was looking at these for an ORP Laramie, but noticed it says only up to 2018 rams?
You're right, it isn't going to "wow" like a 6" lift with 37" tires... but it really gives the Rebel a more "off road" stance that they should have designed onto the Rebel package.Just got the ready lift leveling kit with control arms installed yesterday. Modest change in appearance but I feel it improves the stance considerably. View attachment 13801
For the Mopar uca's from the lift kitI went with the Moto Fab 2" top hat spacers and the Mopar upper control arms from their 2" lift kit on my Rebel. Running Nitto Terra Grappler G2's in 295/70-18, basically a 34x11.5, for tires. Install next week, will post pic's when done.
