ChrisJ796
- Jan 28, 2024
Bought a RAM a month or so ago, have only drove it a handful of times an am getting irritated. Bought it cash off a guy a gave it a walk around test drive ect with no issues. It is a limited eco diesel with a Rough Country lift, I believe it’s 5 or 5 1/2 inch lift and 24x13.50Rx37” tires. After driving it home 8+hrs it was still great after a few quick trips around town started noticing popping when turning and a clunk when stopping starting. After crawling under it I have had to tighten all the drop brackets for front differential, replace numerous bolts that were washed out from being so loose. gained some noise reduction but it still sounds horrible for a 70k+ dollar truck when turning bumps ect… tie rod ends are junk and I have bought new an correct ones from RC just not had time to install. I just pulled off sway at links an both lower boots are ripped a full of rust. I am going to buy suspension MAXX links an am curious if they need to be for a lift or stock considering the lift has drop brackets for sway bar?
