2023 disable seatbelt alarm?
Darksteel165
Massachusetts
Mine is kinda like that, is not that you cannot but the truck will not disengage the parking break unless you buckle up. I can still reach down and manually disengage and drive with out the belt if I want to, just and extra step.
Put the truck into tow haul mode.
Arth
I've downloaded the Jscan App from the apple store. The 2023 is not an option. JSCAN said the 2022 work, but based on this post, im leary. View attachment 178601
I dunno what to tell you bubba except to clean your glasses. Ram DT 1500 2019-2024 lower right in the photo you posted.
MeyerzRam
I’ve got a 3500 with the digital dash. Working with JScan to test. Referred to as the 3500 D2. The screenshot shows it goes to 2021.
Jimmy07
Honorary Site Supporter
Use DJ 2500 instead. JScan and alfaobd both disable the seatbelt chime on digital cluster equipped Rams.
Idahoktm
North Idaho
I finally got around to disabling the seatbelt chime. The ignition has to be in the "ON" position ("MAR" in AlfaOBD language) to do this change. AlfaOBD kept disconnecting from the instrument panel within about 10 seconds, so I had to get through the procedure quickly. I finally got it to change to "disabled" after 3-4 tries.
