2023 disable seatbelt alarm?
BigRedDodge
This is how you explicitly do it.
It works.
Get in your truck close the door.
Buckle your seat belt.
Set truck to run (not acc)
Remove buckle, insert
remove, insert
remove, insert
Leave inserted and turn truck to off
Start truck
I followed this procedure on my 23 Laramie and it worked perfectly on the first try.
lawless
Here’s the procedure I used with my 2022 Laramie that worked first time and still working.
How to disable the seatbelt chime.
Start with seatbelt on and truck off. Press start button with foot Off brake twice to run position, unbuckle and buckle your seatbelt 3 times. Foot on brake and press start button then turn the truck off. Open door.
Thank you! Worked on my 2024 Laramie 2500 Cummins...no more bells.
Eighty
Moderator / Dream Killer
The digital dash is digital, and the analog dash isn’t digital
:D
Different firmwares, and the digital dash seems to have eliminated the override technique
BigRedDodge
:D
This must be the standard dash
DEG
Yes, that's not the digital dash. Below is the digital dash. I have the digital dash shown below and the seatbelt trick will not work.
Arth
Can confirm again, JScan worked for my 23 limited. Awesome
Nascar Tommy
My other Ram is a Dodge.
NW Indiana.
I have one. You can not move the truck, unless you fasten the seatbelt.
Interesting! I did not know that.
I always wear mine but what a pain in the *** for getting in and out while hooking up a trailer ot whatever.
MeyerzRam
I've downloaded the Jscan App from the apple store. The 2023 3500 D2 is not an option. JSCAN said the 2022 work, but based on this post, im leary. IMG_8096.jpeg
Papi4baby
Mine is kinda like that, is not that you cannot but the truck will not disengage the parking break unless you buckle up. I can still reach down and manually disengage and drive with out the belt if I want to, just and extra step.
