Just adjusted them another 3 turns (1/4), couldn’t tell with my driveway. OR1 and 2 work with no issues, just tried them both.Looks good sir! How’s the ride quality and function of the or1 and 2 with that setup?
How much did you set the at originally? I think I did 6 turns.Just adjusted them another 3 turns (1/4), couldn’t tell with my driveway. OR1 and 2 work with no issues, just tried them both.
They came kinda short so I set them as close to the factory ones as I could, I made them a little longer than the stock and put them on. After that probably 6 turns. I think I have it where it needs to be now. im Really happy that all the factory settings still work too, not that I have any need to use OR1 and 2.How much did you set the at originally? I think I did 6 turns.
[B][U]Went with the 1.5" for mine[/U][/B]...hope that wasn't a mistake, but with the Air Ride...I'll probably never be taking a hard turn with it in Aero or lower.
Got my level on last weekend, just waiting on wheels/tires for the 23 Laramie GT.
Plan on doing some 18" Vision wheels and 35" tires so it'll fill out the wheel well nicely.
did it immediately so never had a chance to notice....but I had 2" level and 35s on my 2019 with standard suspension and I really don't think the air ride is that significant on ride quality over all. That's not why I bought it anywayDid you notice any change in the ride characteristics from the level?
Great thread. I'm new here but have had '19 Laramie for 4 years and just got a 21 limited (looks about identical to Josh 24's truck.) So I can sure weigh in on ride quality comparing my 2 trucks: the '19 Laramie on 18s (standard size Firestone Destinations) rides like a dream in comparison to the '21 Limited with Air ride. Handles better and feels more secure on the road. The '21 Limited has 12.5X35 Yokahama X-AT's and (according to my dealer) some sort of "adjustable bracket" that is a leveling kit. That's why I originally came to this forum. I much prefer the ride of the old truck but the look of the new one is stunning! The hit overall on gas mileage is about 2mpg (though hard to tell since the enormous tires have also thrown off the odo and speedo by about 7%). It should also be noted that the new one has the 3.92 axle whereas the '19 has the 3.21 which also affects the mileage and day to day drivability. The dealer has warned me that the "Adjustable bracket" that provides the level could have a bad impact on other suspension parts and even the reliability of the Air Ride itself. Based on this thread it seems I would need to know a lot more about which level bracket was installed and what other mitigating steps they might have taken. Any other thoughts on any of these topics welcomed!View attachment 165798
I'm assuming that the previous owner just got the adjustable links, and no spacer, and that is why the ride is worse. Well, that and the LT mud terrains of course.Great thread. I'm new here but have had '19 Laramie for 4 years and just got a 21 limited (looks about identical to Josh 24's truck.) So I can sure weigh in on ride quality comparing my 2 trucks: the '19 Laramie on 18s (standard size Firestone Destinations) rides like a dream in comparison to the '21 Limited with Air ride. Handles better and feels more secure on the road. The '21 Limited has 12.5X35 Yokahama X-AT's and (according to my dealer) some sort of "adjustable bracket" that is a leveling kit. That's why I originally came to this forum. I much prefer the ride of the old truck but the look of the new one is stunning! The hit overall on gas mileage is about 2mpg (though hard to tell since the enormous tires have also thrown off the odo and speedo by about 7%). It should also be noted that the new one has the 3.92 axle whereas the '19 has the 3.21 which also affects the mileage and day to day drivability. The dealer has warned me that the "Adjustable bracket" that provides the level could have a bad impact on other suspension parts and even the reliability of the Air Ride itself. Based on this thread it seems I would need to know a lot more about which level bracket was installed and what other mitigating steps they might have taken. Any other thoughts on any of these topics welcomed!View attachment 165798
Do you have a picture of your front links? Then we will know what they are. You probably don’t have a spacer, which is why is doesn’t ride as good. Also take a pic of your rear links. What size tire are you running here? Looka like t you have wheel spacers as well.Great thread. I'm new here but have had '19 Laramie for 4 years and just got a 21 limited (looks about identical to Josh 24's truck.) So I can sure weigh in on ride quality comparing my 2 trucks: the '19 Laramie on 18s (standard size Firestone Destinations) rides like a dream in comparison to the '21 Limited with Air ride. Handles better and feels more secure on the road. The '21 Limited has 12.5X35 Yokahama X-AT's and (according to my dealer) some sort of "adjustable bracket" that is a leveling kit. That's why I originally came to this forum. I much prefer the ride of the old truck but the look of the new one is stunning! The hit overall on gas mileage is about 2mpg (though hard to tell since the enormous tires have also thrown off the odo and speedo by about 7%). It should also be noted that the new one has the 3.92 axle whereas the '19 has the 3.21 which also affects the mileage and day to day drivability. The dealer has warned me that the "Adjustable bracket" that provides the level could have a bad impact on other suspension parts and even the reliability of the Air Ride itself. Based on this thread it seems I would need to know a lot more about which level bracket was installed and what other mitigating steps they might have taken. Any other thoughts on any of these topics welcomed!View attachment 165798
| Readylift 1.5 leveling kit (possible revel rear links needed?) | Revel 2.0 Advanced lift package (up to 2.5 total lift) |
| no links | Revel links |
| Readylift metal spacer (description says steel, details say aluminum) | Daystar polyurethane spacer |
| Readylift upper control arms | Readylift upper control arms |
| Max Tire (285/65r20) = 34.6 (Toyo AT III), 34.8 (Nitto Ridge Grappler) | None listed |
| $529.95 (+ opt rear revel @ $149.99 = $759.94) | $899.99 ($929.99 w/links pre-adjusted) |
Hi, Steve. I contacted Revel about their Advanced Kit (Daystar spacer, Readylift control arms, and Revel Links), and they stated the following:Hello all:
This has been a great thread - so I thought I would continue rather than start a new one. Here are a few remaining questions that I have:
1. As I measure my truck in its stock setting (21 Limited), I have a 2 inch rake from front to back. This seems consistent across all five air suspension heights with very minor differences. Is this consistent with other people's findings? So, If I still want about 1 Inch of rake after then I only need about 1 inch in the front OR 1.5 inches in the front plus .5 inches in the back to keep that rake?
2. I think I saw that both the Daystar spacer and the Readylift spacer are both actually about 1.5 inches in height. Can anyone confirm this?
3. On a previous vehicle I found that the front end layout of components meant the height of a leveling spacer resulted in 2X the vehicle height increase due to the geometry of the suspension. Does anyone know if this is also the case on the Ram?
4. Is there an alternative to the Daystar or Readylift spacer that does a better job of giving a true 1 to 1.5 inch lift to the front of the truck.
5. What size tires have people tried after a level? By my analysis, here are the sizes I have been thinking about:
275/55/20 - stock - basically a 32" tire
275/60/20 - big - basically a 33" tire
275/65/20 - bigger - basically a 34" tire
It looks like both the 33" and 34" should be able to fit without rubbing but any additional experiences would be appreciated.
I am particularly interested in what folks have found in terms of mileage reduction.
6. Are folks getting their speedometer re-calibrated at a dealer? Is this difficult? What charges are people getting for speedometer recalibration. Is there a DIY solution - maybe with on OBD device that's easier, or more accurate than using a dealer?
Thanks all - much appreciated. Please keep the information flowing!
Cheers, Steve.
Did you do the daystar pucks as well or just used the links?Maybe can’t tell from the pic and my driveway, but it’s level.View attachment 164096
Is this with oe links or aftermarket?Just installed ReadyLift 1.5 leveling kit with UCA. No issues smooth ride. Trying to decide what tires to run.Currently running 22X10inch +24 offset
tires 305/45R22
Looks like u retained rake in the rear is this pic in aero or normal?OE , no sway bar issues , friend at dealership adjusted setting, have all 5
sits perfectly level View attachment 175848
