boogielander
- Jun 29, 2022
it's along the colorado river between commiefailnia and AZ. South of I-10That river looks amazing, would you mind sharing the location?
holy F -40F.This cold up in the northern midwest is simply brutal for car/truck batteries. Years ago I was in Alberta looking for an oil field job. I parked my trusty 77 gmc 400 propane powered 1 ton and the next morning the propane tank was frozen up. Wind had been blowing and it was -42 C which is basically -40 F.
It took till noon in the weak sun shining on the black painted side propane tank before it thawed. Had to get the truck jumped as well.
After that winter I departed for Arizona as I was done with cold, never been back. You northerners have my sympat, I mean respect for staying up there.
Thats not too bad for Canuckers. Heres what the news said about yesterday up where I was living in Red Deer, AB:holy F -40F.
ok now i'm curious. how does it feel? i heard that when the temperature gets low enough to a point that it just feel the same.Thats not too bad for Canuckers. Heres what the news said about yesterday up where I was living in Red Deer, AB:
By Sheldon Spackman
JANUARY 15
More record low temps set throughout central Alberta Monday
Jan 16, 2024 | 12:31 PM
“The arctic air mass that made its way throughout Alberta over the past several days set a couple more temperature records throughout the region on Monday.
According to Environment and Climate Change Canada (ECCC), the Three Hills area set a new record low temperature for January 15 on Monday, dipping to – 43.5 degrees Celsius, beating the old record of – 43.3 degrees Celsius set in 1950. Records in the Three Hills area have been kept since 1921.”
When using the C to F converter :
-43.5 °C = -46.3 °F
So I was off a few degrees, low.
Cold is cold. But we have about 3 months to get acclimated to the weather (Fall season). I've gone snowboarding in Vermont when it was -6 °F. You'll feel it more if you're just visiting, and coming from some where warm. Your body needs time to adjust.ok now i'm curious. how does it feel? i heard that when the temperature gets low enough to a point that it just feel the same.
-40F is nothing!holy F -40F.
I'll take Az over the humiditybetter every year![]()
I went to Yuma, AZ before. It was 99 F at midnight and 116 F at noonI'll take Az over the humidity![]()
That pesky global warming is at it again.Thats not too bad for Canuckers. Heres what the news said about yesterday up where I was living in Red Deer, AB:
By Sheldon Spackman
JANUARY 15
-43.5 °C = -46.3 °F
I've lived in 4 seasons for 49 years, you can have it!I absolutely hate hot, humid weather, but the heat in AZ sucks almost as bad. I lived there for 20 years and the constant 110°+ temps just wear on you. You can't do anything, unless you're neck deep in a pool or indoors. No thanks...I'll take 4 seasons any day over that crap.
I've lived in 4 seasons for 49 years, you can have it!what 4 months of heat, maybe 5 and the rest great!! I'll take that anyday.
"They all do that" or "could not replicate"Take a wild guess that they came back with?
