No GPS Signal on Navigation
Bin01123
Atlanta, GA
I just bought a 2021 Ram 1500 Limited with 65K miles. (out of warranty) I just noticed a few days ago that the factory navigation GPS isn't working. I use AppleCarPlay anyway but I would like this to work if it doesn't break the bank. Please let me know if there is anything else I should check in order to fix this
- Check to see if the Telematics Module is still installed (I have to figure out where its located first) Thanks @HSKR R/T for telling me about this
- Check to see if the GPS is connected to the main unit
- Check the status of the antenna for damage
- Maybe there is an issue with the LTE card in the head unit
RamCares
Michigan
Our team would like to see where we can best support you. Can you please send us a private message with more details regarding when this concern first became present so we can look further into this?
Dakota
Ram Cares
Dr. Jim
I had a similar situation on the unit in my 2018 Durango SRT. Message was "Searching for GPS Signal." Face plate had also delaminated. Dealer replaced entire unit (October, 2023). It took about 6 months for replacement to arrive. Everything was completely covered under my extended warranty.
Tallus
Bin01123
Atlanta, GA
Dakota
Ram Cares
just sent a PM
Bin01123
Atlanta, GA
Thanks for this. I'd like to try the software update first if I can get the truck to take the update
Bin01123
Atlanta, GA
Just tried the software update and it wasn’t successful. I received this message once the update got to 19%
Bin01123
Atlanta, GA
So I had my truck in for another issue and I had them look at this issue while it was there. The said it needed a software update and I'm going to let them do it while its there. They said the software update will take 4 hours. Does that sound right?
@HSKR R/T @Darksteel165
The 4-hours is probably book time. Chances are the actual update won't take that long.
