No GPS Signal on Navigation
Bin01123
Atlanta, GA
I just bought a 2021 Ram 1500 Limited with 65K miles. (out of warranty) I just noticed a few days ago that the factory navigation GPS isn't working. I use AppleCarPlay anyway but I would like this to work if it doesn't break the bank. Please let me know if there is anything else I should check in order to fix this
- Check to see if the Telematics Module is still installed (I have to figure out where its located first) Thanks @HSKR R/T for telling me about this
- Check to see if the GPS is connected to the main unit
- Check the status of the antenna for damage
- Maybe there is an issue with the LTE card in the head unit
Our team would like to see where we can best support you. Can you please send us a private message with more details regarding when this concern first became present so we can look further into this?
Dakota
Ram Cares
I had a similar situation on the unit in my 2018 Durango SRT. Message was "Searching for GPS Signal." Face plate had also delaminated. Dealer replaced entire unit (October, 2023). It took about 6 months for replacement to arrive. Everything was completely covered under my extended warranty.
Dakota
Ram Cares
just sent a PM
Thanks for this. I'd like to try the software update first if I can get the truck to take the update
Just tried the software update and it wasn’t successful. I received this message once the update got to 19%
So I had my truck in for another issue and I had them look at this issue while it was there. The said it needed a software update and I'm going to let them do it while its there. They said the software update will take 4 hours. Does that sound right?
@HSKR R/T @Darksteel165
The 4-hours is probably book time. Chances are the actual update won't take that long.
Dakota
Ram Cares
Where
wheres the module located did you find it ?
Where
Please visit our profile or hover the mouse over our username then click " Send direct message." If you need further assistance, please let us know.
Gia
Ram Cares
@RamCares Been facing similar issues since a month where my gps location is lost and shows I’m in a totally different location many miles away sometimes even in the ocean lol did all kinds of reset which doesn’t work for me(holding power and tuner knob), spoke to uconnect team. Still no help, Sirius xm works but no travel link, CarPlay works as usual. What’s happening and considering its a 2019 I’m probably out of warranty luck.
ERROR 20 is the error code of a failing Sierra Wireless Embedded Aircard. Back in the Uconnect 3's, this was Step 11, 67% of the full update, and it effectively bricked the radio. In Uconnect 4's, Error 20 is the same problem. Fortunately, the Uconnect 4's have a recovery mode, so it should restore itself back to the previous software version and you'll have a working unit... However the GPS issue will still exist. We repair this issue and can update it fully after the repair.
Is there no solution for this other than replacing the entire unit? Seems excessive when everything else works great. My 4gen had this around 60k miles and my 5gen is at 95k miles and I just replaced the battery for the first time and noticed this issue. I use gps (both built in and CarPlay) daily and didn’t notice anything until the battery change so I can only assume they’re related? An older car I had I remember having to do all these weird maneuvers in an empty parking lot to recalibrate things - does nothing like that exist for these headunits? I did notice that the tracking issues also appear when using Apple Maps. I can insert direction and it’ll navigate properly showing me on the proper roads etc, but when in regular map mode it shows me driving sideways and over bodies of water etc.
I replaced my card this afternoon in under an hour. Instant success with functioning GPS. My truck is no longer 200mi off the Pacific Coast!
Thank you Tallus!
