1BADRAMLIMITED
Oklahoma
Looks good. Share the link to the light..
Sent from my SM-G781U1 using Tapatalk
one of the reviews on the light suggested the fuse on the ground was an electical fire waiting to happen, with that said i am no electrician but thought i would mention that. i cut the fuse off mine (extended the wires) and ran it to my aux switch panel to control power off/on.
Eighty
Moderator / Dream Killer
Did a little wrenching this morning. New aFe Power “Track Series” carbon fiber cold-air intake. Funny enough, I had to do some digging to find…drum roll…my 10mm socket.
Here’s the difference in tube sizes coming out of the air box.
Ready Go
Wisconsin
Generic but it would be really cool to do one of the lakes I fish or areas I’ve hunted. Would be sick but a whole lotta work.
I think that's the Southern Kettle Moraine topography from Eagle, WI!
I see kettles, kames, lakes..yep, that's SKM..🤣🤣🤣
"Fixed" my truck after trying to get the kill by fob on the TazerDT re-enabled last night and actually enabling kill pedal now. Luckily the truck had enough power at idle to get back up the driveway and into garage without any throttle input. My driveway is slightly sloped. Had to remove the Pulsar because I couldn't turn cruise control on to get through Tazer menus, like you need to do with the Pulsar
Eighty
2021 and older is Uconnect 4 and 2022 and newer is Uconnect 5.... (I believe... i'm sure someone can help me out on that one tho....)
another deciding factor is Uconnect 5 has Wireless Carplay... i believe Uconnect 4 has to be plugged in with usb.
Yes that’s correct.
kapinallinen2
5thGenRams Supporter
Southern Maryland.
What tool is the hub bearing assembly bolts? (#1) 4th gen uses a flexi shallow 18, especially the top, that must be jammed in and risks the boot as the bolt/socket comes out. PITA. GM is much easier, but more often 😄
Pull the half shaft, then use what ever fits.
spencerclift21
Carli 2.5 Performance Suspension with 18x9 -12 offset Method wheels and 35x12.5-18 Toyo Open Country A/T3s
Redz72
Langhorne, PA
As a result of swapping out my halogen headlights with Lasfit LED’s and then lifting my truck a few weeks ago, I got flashed often driving at night. Just spent an hour adjusting my headlight beams back to the road/proper alignment and haven’t been flashed since. Much better now! IMG_9745.jpeg
Dogpatch
Coldstream, BC
As a result of swapping out my halogen headlights with Lasfit LED’s and then lifting my truck a few weeks ago, I got flashed often driving at night. Just spent an hour adjusting my headlight beams back to the road/proper alignment and haven’t been flashed since. Much better now! View attachment 172532
We all thank you! 😎
