Exchanged my oe front struts for a set of ORG struts I bought from a member here. Always felt that this Ram sat too low in the front, I’m quite pleased with the additional height now. Truck doesn’t actually ride any different, which was somewhat of a surprise.
Kudos to @Waterfowler41 for a piece of advice on one of his posts, disconnecting both lower stab links before I started seemed to contribute to smooth removal and installation.
View attachment 171634 View attachment 171636 View attachment 171637
What's with all the bungee cords?
HemiDude
Ohio
Basically wasn't sure which way anything was going to go when disassembled, so I went heavy on the bungees when I started. By the time I got to the other side I knew what to expect and didn't need them all. They did serve an an extra set of hands at times so that was beneficial.
Redz72
Langhorne, PA
Good call! Better safe than sorry. I pulled the axel bolt so if it did drop too much it wouldn’t pull out the axel.
RAM Patriot
Clayton GA
Morning commute intersected with a deer. :confused:
Did not turn out well for me or the deer. :cautious:
The engine light and the Windshield washer fluid light both came on the next time I cranked the truck.
The buck got his antlers into the AC condenser as well as the washer fluid reservoir.
He also took out the grill shutters which caused the engine light to come on the dash.
CogitoErgoLevo
Los Angeles
I like that about my Limited. With the OEM air bags, It lowers down into “Aero” mode (squats) at 60mph and in theory, saves $$$.
Stellantis claims a whopping 2% mpg reduction in aero mode compared to regular mode(insert giggles here). That 2% applies to speeds above 60mph. Under 60mph, it's even less.
It only lowers the truck by 1/2 inch anyway.
BowDown
Frisco TX
Those %'s add up
Rock Crawler
Lone Star State
Well heck, then my 2/4 drop must be getting me at least 5%.
Belvedere
And since we're dealing in corporate math here...
I was going to lift my truck, which would have a given me a loss of >5%, but I didn lift yet, so that's a >5% gain for the year, right?
JamRam
But you're only gaining on the future while running at a present loss, based on what was possible historically. 😁
Dogpatch
Coldstream, BC
I see math wasn’t too popular with some. LOL
Shoulda paid more attention during the guzinta’s and divide-by‘s classes.🤪
ramButz
syracuse,ny
Wow finally after almost 3months,finished up my mod on "HydroDip"🥵🥵as i did earlier on my hood louvers.had to do it myself.not one person in my area wanted to do it for me..so as before i had to try and do it myself🥺😢.these are the interior parts
There used to be a couple local shops by me that did hydropips. One was a friend. They have all stopped doing it because of the huge increase in material cost, and low demand. It just wasn't worth their time, and most customers didnt want to pay the prices they had to charge, even just to break even.
Redz72
Langhorne, PA
Are you going for the “murder scene” interior design look?🤣🤣. That’s bad@$$.
ramButz
syracuse,ny
yeah maybe your right..its why i had to do it myself for that reason.i would not do it though for others :cry:
Morenar
West Central Florida
Took advantage of BDS Black Friday sale and picked up a 6 in PE coilover kit to replace my Readylift 3.5. I’ll be selling that kit after it comes off. Have replacement bushing and ball joints from readylift for both sides that would need be replaced . So it well practically be a new kit. Will post it on the forum for sale after it’s removed.
