New info on Gas tank fueling issue
FLiPMaRC
NJ
I got my truck back and have filled up twice without issue. The dealership said they replaced the ESIM. That is the only part that is noted on the work receipt except the fuel they added for their tests.
I got under the truck to look around when I got it back... I could swear the gas tank looks new. The factory white stickers are still on it without a stain! I can't imagine those held up 15k miles in MN winter and dirt roads + many car washes with under carriage blasts in the condition they are now. Maybe they replaced the tank and didn't say? I think a single car wash might take those stickers off. Anyway, maybe they only replaced the ESIM, maybe they did more. They had my truck for 6 days claiming a wait on the ESIM.
Considering how cheap the ESIM part is and relatively easy to get to, it might be a good starting point for those out of warranty. Fingers crossed this one goes further than 10k miles which is about where the first one began having issues.
What year, model, tank size do you have???
theblet
The evap module prevented fueling? How does that work? Maybe they did put in a few tank?
Arc72
Красноярский край
Может это всё таки адсорбер? Большая чёрная коробка на баке похожая на воздушный фильтр? У меня Ram 1500 2019g и то же есть некоторые проблемы при заправке. Скоро зима продул все трубки от заливной горловины до обратного клапана сам клапан двигается хорошо да же от воздуха сегодня буду заправляться там где раньше не мог посмотрим как это получится.
theblet
I don’t know Russian but let’s try this,
большая коробка, о которой вы говорите, вероятно, является канистрой с углем для системы испарителя
blunderblorm
I am not really certain yet, I'll try to get under the truck again when I have time. It seems it could be the ESIM only, it has a weight that moves tied to a plenum of some sort acting as a check valve. It could in theory block flow to the canister from my understanding of it. From the page below:
"During fill-up, vapor pressure from the tank pushes the heavier yellow weight off its seal and gas vapor flows into the charcoal canister. The pressure also pushes the diaphragm away from the electrical contacts. The ESIM contacts receives a reference voltage from the PCM and the PCM monitors voltage drop. When the system is under pressure and the diaphragm is pushed away, the contacts aren’t closed so the PCM sees no voltage drop."
Arc72
Красноярский край
Я пока не совсем уверен, попробую еще раз залезть под грузовик, когда будет время. Кажется, это может быть только ESIM, у него есть груз, который движется, адвокатный к какой-то камере, действующей как обратный клапан. Насколько я понимаю, теоретически это может блокировать поток в канистру. Со страницы ниже:
«Во время заправки давления пара из бака отталкивает более тяжелый желтый груз от его уплотнения, и пару газов оставляют в канистру с углем. Давление также отталкивает диафрагму от электрических контактов. Контакты ESIM получают опорное напряжение от PCM. и PCM контролирует падение напряжения. Когда система находится под напряжением и диафрагма отталкивается, контакты не замыкаются, поэтому PCM не видит падения напряжения».
Вы ребята не заметили, как иногда пахнет бензином от нашей машины? И это очень сильный запах. Что касается угольной коробки, как вы ее называйте. У друга на Мерседесе произошло обратное разряжение, когда был заполнен угольный фильтр, и был большой вздох при открытии бака. Это может быть и в обратную сторону.
theblet
я никогда не замечал никакого запаха. вы должны прекратить заправку, когда щелкнет форсунка, чтобы предотвратить попадание топлива в канистру.
Arc72
Красноярский край
А теперь по поводу заправки пишу как и обещал. Сегодня заехал опять на заправку где не смог заправится до продувки всех трубок и обратного клапана. Пистолет заправщика включил на полную мощность. Заправка прошла до отсечки ( первого щелчка) без остановки. Думаю что продувка через угольную коробку каким то образом даёт барану заправляться без проблем. Это лишь мои предположения но это пока помогает.
Arc72
Красноярский край
Обратите внимание когда будете стоять с ветром дующим в задний борт машины как запах будет ощущаться в салоне машины. Я несколько раз выходил из машины проверить не перебит ли бензопровод под капотом машины думая что есть утечка из бензопровода, а это косвенно указывает, что угольная коробка не справляется со своей работой.
theblet
иногда я не останавливаюсь, когда он щелкает. я просто замедляю насос и могу вместить пару дополнительных галлонов. до сих пор никогда не чувствую запаха газа. возможно у тебя канистра треснула или вентиляционное отверстие сломано
Arc72
Красноярский край
иногда я не останавливаюсь, когда он щелкает. я просто замедляю насос и могу заменить дополнительную пару галлонов. до сих пор не чувствую запаха газа никогда. возможно у тебя канистра треснула или вентиляционное отверстие сломано
Не, под машиной сухо. Отверстие это салонный фильтр? Если про него то он работает но не так как на TOYOTA LANDGRUSER 200
theblet
После продувки через бак и угольный фильтр заправился очень быстро и без остановки
Это хорошая новость. Может быть, там был засор. До сих пор не знаю, почему вы чувствуете запах газа в кабине. Возможно, придется попросить кого-нибудь взглянуть на него.
Sparcky
this has happened on my 2023 Laramie Sport a bunch of times. Have to hold the nozzle up on an angle and it fills ok.
Arc72
Красноярский край
это случалось с моим Laramie Sport 2023 года несколько раз. Приходится держать насадку под углом и наполняется нормально.
С каждым разом скорость заправки будет сокращаться пока не дойдёт до нуля. Перед предстоящей зимой это будет проблемой. По этому лучше всё сделать заранее.
Arc72
Красноярский край
Это хорошая новость. Может быть, там был засор. До сих пор не знаю, почему вы почувствовали запах газа в кабине. Возможно, на этом основаны какие-нибудь последствия.
Сэр! Не могли бы вы выполнить узнать в сервисном центре, может ли быть проблема с засорением адсорбера, проблема при заправке машины?
Wild Bill
NH
доброе утро, хочешь пива
theblet
извини, у меня нет способа сделать это.
