Ramroo
- Jul 1, 2018
I adjusted my past 2 trucks using a large adjustable wrench. Really don’t need the toolHow much was the 'special tool' if you don't mind my asking...
How did you bend the metal loop?I adjusted my past 2 trucks using a large adjustable wrench. Really don’t need the tool
It takes a large adjustable wrench because the loop is pretty tough to bend.How did you bend the metal loop?
I'm trying to tighten my lids down to close the horizontal/bottom gap. I need the loop lower basically so the latch/lid has to come down more to catch.
Ok, I convinced..I'll give it a try this weekend! Can't find the tool (which is my preference) anywhere, so I'll try this. I did use large crescent wrench to get the side-by-side adjusted..might as well try this too!It takes a large adjustable wrench because the loop is pretty tough to bend.
Don’t have truck avail with ram box for pics. The pics will illustrate.
For bending down, work on top and bottom. Also, move wrench on left side and right side as needed, etc.
Same goes for left and right. Pics are reference on how to position wrench. Quite a bit of force at end of wrench. Note: bend loops in ram box, don’t remove and put in vise.
Takes a minute or 2 to figure out leverage, but works well.
I adjusted down, and side to side also. There is limited room on maneuvering wrench. I had to try wrench upright and upside down.Ok, I convinced..I'll give it a try this weekend! Can't find the tool (which is my preference) anywhere, so I'll try this. I did use large crescent wrench to get the side-by-side adjusted..might as well try this too!
Thanks![]()
I can see it'll be tight for the up/down adjustments for sure.I adjusted down, and side to side also. There is limited room on maneuvering wrench. I had to try wrench upright and upside down.
I can’t remember if I was able to work on bottom for moving down due to limited room. Maybe bending just top down worked.I can see it'll be tight for the up/down adjustments for sure.
That's what I'm try now..sketchy thoughI can’t remember if I was able to work on bottom for moving down due to limited room. Maybe bending just top down worked.
I with all the bad press on these ram boxes why in the world did Ram make them standard equipment on the new 2025 1500 limited? I don’t understand why someone should pay north of 80 grand and have to worry about warping Rambox lids and alignment issues. In addition most of us aren’t buying the limited to throw tools and such in the bedsides. We are buying them for comfort while pulling our toys. I have an 25 order pending at dealer for a limited but I don’t want the rambox and there isn’t a delete option for the 5.7 box. Now I am measuring in the morning to see if the 6’4 will fit in garage. I have drove silverados for years but GM has me ticked off this round So I am going to try a Ram.No. My 2020 RAM is only 1 month old and my lids are already warping. I took it to the dealer and they took pictures and made a note of it. They told me they would be more than happy to replace the boxes if I wanted to. They told me it’s a vendor problem. They’ve already had to replace some boxes on other customers trucks. My lids are not as bad as some other pictures I have seen. Right now it does not bother me too much but I just wanted the dealer to make a note of it in case it gets worse
.I with all the bad press on these ram boxes why in the world did Ram make them standard equipment on the new 2025 1500 limited? I don’t understand why someone should pay north of 80 grand and have to worry about warping Rambox lids and alignment issues. In addition most of us aren’t buying the limited to throw tools and such in the bedsides. We are buying them for comfort while pulling our toys. I have an 25 order pending at dealer for a limited but I don’t want the rambox and there isn’t a delete option for the 5.7 box. Now I am measuring in the morning to see if the 6’4 will fit in garage. I have drove silverados for years but GM has me ticked off this round So I am going to try a Ram.
It's not a programming error, they did it on purpose..
It does seem odd that Ramboxes are standard. I'd bet that it's a programming issue with the build & price website, and even the ordering screens the dealers use have been known to have anomalies. Maybe wait awhile and see if the ordering websites get straightened out closer to the actual model year production.
I don't use my Ramboxes for tools, I put ropes, tiedowns, extra DEF, a couple of towels, etc., so it keeps the cab free of a lot of that stuff.
I went ahead and just got the 6’4 bed on it last night. I am honestly too picky to take a chance on seeing those ram boxes not fit right in the mirrors..
From what I understand we have differnet Ramboxes then what you had, we have gen 2.I couldn't live with mine; I had a 2019 power wagon with them, and they were horrible. dealer "fixed" them once and they came loose 3 days later. They were warping and actually starting to rub paint off on either end. Dealer told me they wouldn't be able to keep them from warping. I ended up trading for a non ram box truck. I couldn't justify the price of the truck and it to look like absolute dog ****. It's a shame Ram had to cheapen them to the point they warp so badly. Same thing with the ever present 3rd brake light leak that they also can't/won't fix.
the top should be metal …. and that would help with warp and alignment … mines been great they warped and i just added some modifications to have it stay downFrom what I understand we have differnet Ramboxes then what you had, we have gen 2.
The real problem is they are 100% plastic, plastic will melt and warp under the sun.
I think it should be metal like the body of the truck that doesn't warp.
