blacksheep37
- Aug 29, 2023
That is a ctually a clever idea!Changed the oil this weekend. Installed the fumoto valve, the nipple is closer to the sway bar than I hoped. I guess I’ll find out it the next oil change if I can get good drainage from a tube, I suspect not.
On a more positive note, I draped a puppy pad over the frame and rack, and it did a great job.
same here, plenty of room. also have the orgI have the same fumoto valve but mine is not as close as yours. I wonder what the variable is that makes some closer than others? I have a limited with ORP
With all these valves aren’t you leaving a bunch of crap in the bottom of the pan as the valve has to sit higher internally than just pulling the whole plug.I have the same fumoto valve but mine is not as close as yours. I wonder what the variable is that makes some closer than others? I have a limited with ORP
I like those. Do you have a link to the person you bought them from?Added some AJT knob covers that I bought in the Buy/Sell forum on this page. It's a real simple upgrade but looks so much better!
www.ajtdesign-llc.com
It leaves an insignificant amount of oil in the pan.With all these valves aren’t you leaving a bunch of crap in the bottom of the pan as the valve has to sit higher internally than just pulling the whole plug.
Agreed it may leave a few ounces if that but that’s what an oil filter is for right?It leaves an insignificant amount of oil in the pan.
Agreed it may leave a few ounces if that but that’s what an oil filter is for right?![]()
Looks Good! I've been contemplating swapping out the OEM LED. What made you go with this brand and headlight? I wish the projector frame was black.Obligatory, didn’t happen today but installed the Form headlights on my Rebel. Love the look and was pleasantly surprised at their performance versus the factory LED reflectors.
Side by side comparison starts at 12:30 if you want to get right to the review and skip the install.
Good to know! Thanks for the input. I'm in Lemont.I like the way these look compared to Morimotos and AlpalhaRex’s. Also Form is related to Diode Dynamics which has awesome customer service so it was an easy decision.
And personally, I try to support midwestern companies whenever I can (Form is out of Missouri).
I just moved there, nice little town. I grew up in, dare I say JolietI grew up in Lemont!
I just moved there, nice little town. I grew up in, dare I say Joliet![]()
Looks good but why didn’t they weld this part all the way through? Looks unfinished..Got better picture of the new rear bumper from www.wickedbumpers.com
Still waiting on park sensor clips.
