FitCamX dashcam
myfast3rdgen
Chicagoland Area
Parking guard only works if it’s hard wired to constant 12v, otherwise it does not if the truck is off.
It is hardwired. I spent the extra money and time to hardwire it but the parking guard doesn't work.
And before you ask - yes I wired it correctly and yes there is a blinking light on it when the power is off. :)
myfast3rdgen
Chicagoland Area
I've never had to disconnect Bluetooth to connect to the camera. Only connection to camera is wifi
Maybe it's just my phone but I have to turn off my wifi and my bluetooth. If one is off and the other is on it will turn the one that is off, on. I think it has to do with AndroidAuto because it uses both Wifi and Bluetooth. It if notices one isn't turned off it does it for you as long as it has one connection.
O'Town Ram
I know less and less about more and more
Orlando, FL
I have to disconnect my blue tooth ( Iphone) but really what it is doing is disconnecting the phone from CarPlay.
I cannot connect to camera if connected to Carplay
O'Town Ram
Orlando, FL
And it is turned on in the app?
I don't have wireless android auto. Might be part of it.
blacksheep37
I just ordered my FitCamX and went with the front and rear setup. I also want to put in the digital rearview mirror. The question is this - if I install the DRVM, can I splice that in to be the rearview camera on the FitCam? That way I'd only have one camera in the back and nothing sticking to the rear window.
Noz doesn't work that way. Different signals
6of36
Michigan
We only wish. But to expand HSKR R/Ts answer, one is analog, and the other is digital.
JOzzz
Just installed mine, 4k front and 1080 rear. Took about 20 min start to finish. Ran my rear cable along the bottom of the passenger side and had about 6” of extra cable that I tucked into the rear passenger seat belt trim.
Quality is good and app works better than the others I tried. Fit and finish is perfect and other than the Fitcam sticker on the side, it looks factory.
deeve
Hillsboro, Oregon
Any issues with radio reception running the wires that way?
JOzzz
Front Video
Rear Video
Rear video is still processing and will take about 20 more minutes before it finishes processing HD.
They have stickers now?
Eighty
Moderator / Dream Killer
I ran mine through passenger headliner. No issues with am/Fm reception
Do you have any pictures of the headliner/wiring/routing that you did? I still haven't run the rear cam - partially because I'm lazy, and partially because I haven't made up my mind how I want to run it. Ideally it would be along the passenger side headliner like you did, but was wondering if it would all tuck into the gaps (and how it would pass across the trim pieces at the doors). I'm curious if it is 100% concealed when it's all done.
Pull the seals down for doors, popped the top of A-pillar, B-pillar, and C-pillar loose. You can pull down the edges of headliner slightly to tuck cable up. There about 6' of extra cable I cooked up and have tucked in empty space behind C-pillar trim. There really is nothing to take a picture of because you can't see anything.
I thought about trying to route down and along bottom of doors under the door sills, but that was a lot more stuff to remove.
JOzzz
Ahh, yeah, forgot about that one as you cant really see it once installed
6of36
Michigan
I didn't get the front rear, but mine has no sticker. I ordered as soon as it was available though, long before I ordered the truck.
