Got the deflector on today. Turned out nice.
@iupui1299 Looks great man! I may do this..
What type of dash cam do you have and is it hardwired? I was thinking about going with a Blackvue DR900s, not sure if I want the rear cam or not.
After an interior/exterior cleaning I finally got around to putting on my WeatherTech mats, black plate frames, replaced the plastidipped rear badge with OEM, hitch cover, and painting my hood badges black.
The Gator TriFold Pro was delivered today, and I put it on.
What did you use to paint the hood badge? And how did you get them off?
It’s just a 2.7” YI 1080P wide angle cam. Nothing fancy but takes good footage and was pretty cheap through amazon.
Added some bigger tips after deleting all 3 resonators and going with a flowmaster super 10 which I highly recommend because it sounds nasty! Definitely a head turner but tolerable enough on a highway cruise. 275F25A2-0098-4BDA-9B2A-FEA8500FECBB.jpegA177435C-4B99-42DC-A409-3E48DEBF96AD.jpeg840B4D51-FB7E-4742-906A-BBF5FC8143C1.jpeg6C06D92A-B178-44AB-9DA1-A48CDAB0A333.jpeg
I have the same cam in my truck and the wife’s Jee and it’s been pretty solid. Pulling the SD card and looking at footage on the computer, it’s pretty dang good for what I paid.
Hardwired?
Hardwired?
No. It came with a super long cord and I just routed it under the front of the headliner and down the pillar, under the dash, and into one of the many plugs that are available in both vehicles. I wasn’t going to hard wire it since it was pretty cheap and I wasn’t sure how it would go. Since then I haven’t thought twice about it lol.
There’s a couple tabs, one approximately between the 1 and 5 and the other between the H and E. I used fishing line until I hit the tabs, then slowly lifted the corners until able to pull the tab out on both sides, followed by fishing line to separate the remainder of the badge from the adhesive and hood. Painted with Plastidip.
Ordered a Magnum headache rack, I plan on doing some custom work to it by removing the lights and light mounts it comes with and exchanging them with 4 rigid industries chase lights. I'll do a full write up when its completed.MagnumTruckRack_LowPro.jpg90133-ChaseRed_Angle_5.jpg
Do you guys know of anyway to have the Daytime Running Lights only activate the edge LEDs on the headlamps and leave off the nighttime lights?? Just looking for that sharper look....
