iupui1299
Got the deflector on today. Turned out nice.
jk101
@iupui1299 Looks great man! I may do this..
What type of dash cam do you have and is it hardwired? I was thinking about going with a Blackvue DR900s, not sure if I want the rear cam or not.
LoRAM
After an interior/exterior cleaning I finally got around to putting on my WeatherTech mats, black plate frames, replaced the plastidipped rear badge with OEM, hitch cover, and painting my hood badges black.
Longhorn5G
The Gator TriFold Pro was delivered today, and I put it on.
Creep0321
What did you use to paint the hood badge? And how did you get them off?
iupui1299
It’s just a 2.7” YI 1080P wide angle cam. Nothing fancy but takes good footage and was pretty cheap through amazon.
Maric550
Atlanta , Ga
Added some bigger tips after deleting all 3 resonators and going with a flowmaster super 10 which I highly recommend because it sounds nasty! Definitely a head turner but tolerable enough on a highway cruise. 275F25A2-0098-4BDA-9B2A-FEA8500FECBB.jpeg A177435C-4B99-42DC-A409-3E48DEBF96AD.jpeg 840B4D51-FB7E-4742-906A-BBF5FC8143C1.jpeg 6C06D92A-B178-44AB-9DA1-A48CDAB0A333.jpeg
Jsvt3
5thGenRams Supporter
Central Pa
I have the same cam in my truck and the wife’s Jee and it’s been pretty solid. Pulling the SD card and looking at footage on the computer, it’s pretty dang good for what I paid.
Creep0321
Hardwired?
Jsvt3
Central Pa
Hardwired?
No. It came with a super long cord and I just routed it under the front of the headliner and down the pillar, under the dash, and into one of the many plugs that are available in both vehicles. I wasn’t going to hard wire it since it was pretty cheap and I wasn’t sure how it would go. Since then I haven’t thought twice about it lol.
LoRAM
There’s a couple tabs, one approximately between the 1 and 5 and the other between the H and E. I used fishing line until I hit the tabs, then slowly lifted the corners until able to pull the tab out on both sides, followed by fishing line to separate the remainder of the badge from the adhesive and hood. Painted with Plastidip.
Jordan2929
Syracuse NY
Ordered a Magnum headache rack, I plan on doing some custom work to it by removing the lights and light mounts it comes with and exchanging them with 4 rigid industries chase lights. I'll do a full write up when its completed. MagnumTruckRack_LowPro.jpg 90133-ChaseRed_Angle_5.jpg
rickyusf54
Do you guys know of anyway to have the Daytime Running Lights only activate the edge LEDs on the headlamps and leave off the nighttime lights?? Just looking for that sharper look....
