Low volume from door speaker locations
rushingad
Louisiana
Need some audio advice. I have a 2020 Bighorn 1500 with the Alpine system and the 6x9s in the door panels seem to have barely any sound coming from them. At max volume I can hold my ear directly against the speaker and not really hear much. I'm honestly concerned that there's a problem with my amplifier given how quiet they are. I would like to have more highs in the doors so what I'm wondering is if I were to put some 2-way 6x9 in, would the tweeters mounted on them actually work? Or, are those factory speaker locations run through crossovers, blocking the high frequencies from them.
Turn up your bass and you will hear more. Front doors are lows only. Dash are highs.
check your sound placement in your audio settings. it might be towards the back so your not getting much from the front. try centering or moving it forward if this is the case. (seen this happen to someone before)
