- Jul 25, 2020
No, but there are actual body ground points near the fuse panel behind the driver's side kick panel.Are the fuse box mounts bolts good for a ground? what is the bolt size/diameter?
Exactly what I said aboveNo, but there are actual body ground points near the fuse panel behind the driver's side kick panel.
I mounted it (Blackvue 750x....shoutout to @securityguy for his recommendation and the phone conversation!)...on the fixed rear glass as close to the slider as I could get it. Up near the top of the glass. That way I can open and close the slider with no issues. The view is ever so slightly off-center, but the wide-angle lens gives me all the view I want.I purchased a Cobra SC-400D a year or so ago and am just now getting around to installing the rear camera. I successfully routed the wire along the headliner edge and upper door trim. Then I wasn't sure where to mount it. The mounting piece was big enough to go across two of the rear window defroster wires and I didn't want to cover those at all. In the end, I mounted it to the driver's side of the rear sliding window frame. I know the camera will move over if I open the window, but I almost never open it while driving and usually forget it's even back there.
I'm now just curious where other people chose to mount their rear camera?
So on the left side of the sliding window--so it wouldn't hit when the window opens? That makes sense. I guess I could have gone that route. Did yours cover any of the defrost wires?I mounted it (Blackvue 750x....shoutout to @securityguy for his recommendation and the phone conversation!)...on the fixed rear glass as close to the slider as I could get it. Up near the top of the glass. That way I can open and close the slider with no issues. The view is ever so slightly off-center, but the wide-angle lens gives me all the view I want.
My FitcamX rear cameraI purchased a Cobra SC-400D a year or so ago and am just now getting around to installing the rear camera. I successfully routed the wire along the headliner edge and upper door trim. Then I wasn't sure where to mount it. The mounting piece was big enough to go across two of the rear window defroster wires and I didn't want to cover those at all. In the end, I mounted it to the driver's side of the rear sliding window frame. I know the camera will move over if I open the window, but I almost never open it while driving and usually forget it's even back there.
Not that I recall. Currently away from the truck on a trip.So on the left side of the sliding window--so it wouldn't hit when the window opens? That makes sense. I guess I could have gone that route. Did yours cover any of the defrost wires?
Security guy (Larry?) I’m pretty setBuy what you think is best. I've been doing this for over 35 years and I have my own insights on quality and performance. Your money...your truck For me, it will always be a Blackvue.
Blackvue may have different models, with different quality, but when I went to their site, THEIR VIDEO had pretty poor quality compared to videos I saw from Fitcamx users. That, and the fact you have wires dangling, with a Blackvue, where Fitcamx you don't see at all. I bought Fitcamx.Security guy (Larry?) I’m pretty set
On buying a Blackvue dual cam for my ‘22 Limited but confused about which model. Specifically between the DX750-2CH Plus and DX900-2CH Plus. What’s the difference and which do you recommend? I see a 900 on Amazon for $304, not sure if it’s new or reman. Thanks, LarryM
I've looked at Fitcamx, have you downloaded to your phone yet, iOS or Android and how was connectivity? is the 128G max SD card enough memory? Thanks for the input.Blackvue may have different models, with different quality, but when I went to their site, THEIR VIDEO had pretty poor quality compared to videos I saw from Fitcamx users. That, and the fact you have wires dangling, with a Blackvue, where Fitcamx you don't see at all. I bought Fitcamx.
The dual camera FitcamX model is front and rear. The rear camera you mount to your rear window looking out. Sure, you could use it to view inside as well, if you turn it that way, but why?I've looked at Fitcam but don't see a dual rear cam model, just dual front and inside. Up here in winter stop light rear-enders are a reality. What is the difference in Fitcamx "A" and "B" I see on their site, the truck mirror mout? Thanks for the input.
I chose the FitCamX as it's a great idea and integrates nicely with no external wires and looks factory. During my first oil change no one noticed it was there. Video quality is pretty good and you can view on your phone and download the footage. It's a bit slow to connect, but once connected it works fine to look at footage. It doesn't record when the power is off by default, but my home and work have cameras so it's not an issue for me and I prefer the clean install. You can always wire it to a live 12v source like the fuse panel with a kit.I've looked at Fitcamx, have you downloaded to your phone yet, iOS or Android and how was connectivity? is the 128G max SD card enough memory? Thanks for the input.
Push in on it and it pops out.I continue to read about removing the memory card, how is this accomplished?
It's just a micro sd card. Microcenter has them for $8 for a 128g and $16 for a 256g, for the high quality ones.I continue to read about removing the memory card, how is this accomplished?
Thanks, is there a slot on the outside of the housing, or do you need to take it the housing apart to access the card?It's just a micro sd card. Microcenter has them for $8 for a 128g and $16 for a 256g, for the high quality ones.
Someone else will have to answer that. I bought mine when my last order that I didn't accept was being built, so I would have it when the truck arrived. The web site will probably answer that though.Thanks, is there a slot on the outside of the housing, or do you need to take it the housing apart to access the card?
