WasatchBack
- Sep 26, 2018
Looks like my 2021 has the old window.Yeah they revised the window in late 2020 but kinda like the whole exhaust manifold bs it apparently just shifted the problem from one part to the next.
That being said at least from all the threads on here less 21 and up trucks are having the issue but that could just be perspective
The windows part number should be just behind the interior rim on the lower corner of the driver side ( I think, I checked like a year and a half ago ) if you find the newer one and want to check.
Edit: revised number 68426398AE thanks @Burns1200
Looking back on the other threads I’m not sure exactly when that revised window was first installed in the rams but looks like sometime during 2021.
What about the part number sticker behind the driver rear seat trim? Here’s a pic of what mine looks like.Looks like my 2021 has the old window.
Yeah my June build date 21 had the old part number. Didn’t leak but it shattered. Glass guy said it wasn’t fully glued on the frame. This is the new window they installedLooks like my 2021 has the old window.
Damn, I guess they were putting the old windows in for a while then…Yeah my June build date 21 had the old part number. Didn’t leak but it shattered. Glass guy said it wasn’t fully glued on the frame. This is the new window they installed
How are u liking it??Not today, but did do a muffler swap to a Carven TR on Friday.
So far so good. It's a little louder than stock, but nice deep rumble at idle and acceleration. Little bit of drone when MDS kicks in but it's not unbearable. Probably gonna run the resonators for awhile and swap out to the 5" tips here before too long.How are u liking it??
Yeah, it sucks that they denied your warranty claim.Yeah my June build date 21 had the old part number. Didn’t leak but it shattered. Glass guy said it wasn’t fully glued on the frame. This is the new window they installed
iirc you can't use that on pavement. or at least in commiefornia that's the case. Anything above headlight needs to be covered while on pavement.Installed a RLB chase light.
Have it wired up to the trailer 7pin harness with the curt adapter.
Nice having a extra brake light / indicator, running lights and reverse.
The reverse / work lights can be toggled on with a switch inside and they have 7 different strobe modes for the orange running lights.
Also got new tires, went from 275 60 r 20 4 ply falkens to 285 65 r20 falkens. Havent really noticed a difference in ride.
View attachment 162647View attachment 162648View attachment 162649
