- Jul 25, 2020
Good thing you took lots of picturesJust got off the phone with the dealer and I will be meeting with the Manager on Wednesday. Should be interesting.
Good feedback on Core, thanks. Continue to let us know if they come thru with fixes please.Installed the (orange) Hellwig today haha.
Not sure if this is gonna work on an underbody suspension part that is constantly under attack by the elements... Esp in the north east.... BUUUUT what i did was orange plasti-dip... like 600 coats , then 2 coats of a Rustoleum automotive paint orange on top of the dip.
View attachment 162119 View attachment 162118
I've had good luck with the things i have dipped in the past and always been surprised at what it stands up to, albeit, none of them were torsion bars haha. So this could all fall off with the twisting, or whatever else goes on under there, but what i'm hoping is that even if it sort of detaches from the bar, that the dip/paint combo will just stay as kind of a "sleeve" on the bar ... idk but it cost like $12 to do so whatevs if it doesn't last.
And when i placed the axle bushings on the Hellwig i just gently sliced around the bar with a razor knife (sorta how Jason Momoa cut people's heads off in that show "SEE" just with less yelling ) and then peeled those 2 sections off... easy peasy.
View attachment 162120 View attachment 162121
But you have probably noticed that my OEM end links are still on there... not having good luck with the Core ones. got the thin sleeves they made me to be able to use the 10mm bolts at the welded frame nut, and they fit perfectly and would do the trick, BUT, the factory bolt is too short for the new links, not by much, but it doesn't get all the way thru the bolt... thats problem 1.
Problem 2. is the 10mm bolt they sent has a smooth section thats too long for the link, so to get it to actually tighten and be holding the link to the frame, you have to stack the head end with 3 possibly 4 washers... that is too hack-a-licious for me.
Problem 3, however is a new one, where 2 of the 4 johnny joints weren't taking the grease... and when it finally felt like they were, insted of the grease coming out around the ball like it should when its full, instead, the ball joint heaved to one side and on the opposite side an internal gasket looks like its bulging out of the joint itself... and still no grease to be seen... AND those two also seem frozen. Weird... i have an email in to them, but honestly, i've had my links off my truck for no good reason like 3x now... i'm about to give up on these particular parts. A bit annoying.
View attachment 162122 <-- pushed in with bulging gasket View attachment 162123 <-- pushed out View attachment 162124 <-- end view
And the big globs of grease on the zerk, i just hadn't cleaned off yet, but thats all the stuff that wasn't going onto the joint... even after it locked on.
anywhozzle, we'll se what they say... but bottom line for me... i regret the entire upgrade and the cost of it, time, effort, and cost... all except for the sway bar... that is the only thing that actually made a difference and went as expected. They seem like a good company and the customer service has been great, but i'm left not liking that i did any of it.
Looks good, have a safe 4th! Are those 20’s?Quick detail this morning. Happy Independence Day.
Thank you. Yes 20sLooks good, have a safe 4th! Are those 20’s?
I had the same issue with tightening my Core Links. Using the supplied washers from Core, my passenger side tightened just fine. But my driver side still had a gap and would not tighten down. Luckily, I was sent a bunch of free hardware from Hellwig for the end links that included thicker washers. I swapped out the Core washers to the thicker washers and it tightened down perfectly. Hope you get yours figured out. Love the orange, btwInstalled the (orange) Hellwig today haha.
Will do, and yeah they have definitely stood by their stuff and come back with solutions for any problems... Just seems a little tricky when you end up like having to retro-fit a part to work... which... i had more than my fill of that stuff in the Army haha... but these guys are definitely on it.Good feedback on Core, thanks. Continue to let us know if they come thru with fixes please.
Finished the front caliper covers and installed today…..Brembo or Mopar lettering next…..
Looks great, can you tell me where you get the caliper covers from?Finished the front caliper covers and installed today…..Brembo or Mopar lettering next…..
I like them okay looks and function wise. I'm not thrilled with the finish on them though. I'll preface this by saying that I live in an area with a lot of winter salt, and some unpaved gravel roads. I also have large m/t tires that can through stones. With that said, the factory powder coat just didn't last. Less than a year. I removed them, sanded and bedlined them. Now my bedliner is coming off in the same spot, so they need redone. All in all though, I'm not sure any other manufacturer would hold up any better in my environment.How do you like the Nfab Epyx Side Steps?
I have looked at all makes & models & those are the ones I like the best. I just can't seem to pull the trigger on them.
I washed & waxed both the truck & rig today.
We are headed up the coast of Maine for 10 days.
Got the lower grille insert to match the main grille and installed the shifts and grins brackets with the diode dynamics 30 inch light bar behind it.
Also added a little touch of customization to the inside with the personalized bighorn badge.
Nice setup... love the headlights paint match.Got the lower grille insert to match the main grille and installed the shifts and grins brackets with the diode dynamics 30 inch light bar behind it.
Thanks for the info...I like them okay looks and function wise. I'm not thrilled with the finish on them though. I'll preface this by saying that I live in an area with a lot of winter salt, and some unpaved gravel roads. I also have large m/t tires that can through stones. With that said, the factory powder coat just didn't last. Less than a year. I removed them, sanded and bedlined them. Now my bedliner is coming off in the same spot, so they need redone. All in all though, I'm not sure any other manufacturer would hold up any better in my environment.
Good to know... it's weird... how different these trucks can be at one spot haha. and thanks... I do like how the accents came out.I had the same issue with tightening my Core Links. Using the supplied washers from Core, my passenger side tightened just fine. But my driver side still had a gap and would not tighten down. Luckily, I was sent a bunch of free hardware from Hellwig for the end links that included thicker washers. I swapped out the Core washers to the thicker washers and it tightened down perfectly. Hope you get yours figured out. Love the orange, btw
I did not. I figured they would say, and probably rightfully so, that they weren't designed for 35 inch mud tires with no mudflaps, or salty conditions. I have no problem tinkering with them and refinishing them. No real complaints here, just wanted to give you full disclosure on the finish. Now a buddy of mine has some hdx steps on his 2500 and his are visibly rusting, so I guess it could be worse. I don't have any visible rust, just lack of finish.Did you contact the manufacturer for a finish warranty claim?
Today's Thursday.....Just got off the phone with the dealer and I will be meeting with the Manager on Wednesday. Should be interesting.
The meeting went ok, but I am not so sure the Manager took the situation with the seriousness that he should of. They did offer me 4 free services for my truck, which is eh but at least they are trying to make up for it.Today's Thursday.....
I would have told him he can keep his free services, because if they are performed at the same level of competence that your warranty paid sunroof replacement was, they mean nothing to you and you will never use themThe meeting went ok, but I am not so sure the Manager took the situation with the seriousness that he should of. They did offer me 4 free services for my truck, which is eh but at least they are trying to make up for it.
Part of me just wants to be done with it all and then there is a part of me that wants to be a total Karen about it because I feel like they are not taking me all that seriously.
Ugh....
