Atlec
- Dec 1, 2020
I searched around and found several posts related to surging at low speeds but they were all about 2 years old. None of them had fixes listed, so just curious if there has been a fix since then.
Here is what's going on:
At slow speeds (around 5 mph) I will get a surge occasionally in engine speed, ranging from 500 to 1100 RPMs, this causes a noticeable jerking back and forth while the truck is moving.
This seems to occur most frequently after the truck has been started
It will usually go away after 30 to 45 seconds but will occasionally happen anytime.
I took it to the dealership last month but they "couldn't replicate" the issue and no codes present
It was so bad yesterday I thought the truck was going to stall.
This has been going on for at least 2 years but it finally starting to get worse in symptoms and frequency.
2020 1500, 5.7 Hemi (non-etorque), currently has about 45k miles
Thoughts?
Thoughts?
