vincentw56
- Aug 5, 2020
And that info is in the first post. I also added the info about the older trucks.Okay well dang of course not
As long as you followed the first post, it's all listed there.Alright I'm getting ready to do this upgrade now, since I got a 21 with fcw I would need parts #:
68448641AB
68444540AB
The 10ft wires via the Amazon link
And ofc obds for me to enable my auto dim options again
Anything else I'm missing?
Yup I'll be following the post, it seem pretty simple. Plug the new brake lights camera into the front mirror and done.As long as you followed the first post, it's all listed there.
Not for a 2021.Yup I'll be following the post, it seem pretty simple. Plug the new brake lights camera into the front mirror and done.
I wouldn't need any harness right ?
No, but that's my next project. Modifying that CHMSL to add the camera for cargo.2019 1500 Limited
Do any of these CHMSL have a second camera built in pointed towards the bed like a cargo camera or should I get the 2 input camera and add a separate camera next to the light? I would assume that the HD cargo cam lights won't fit my 1500 because its new and the 2500 and up are still 4th gen cab and bed, is this correct?
you tube vid
Grip it and rip it.
i saw a youtube vid where he rip the middle part first and broke the clips lmao, ill look around again and see if i can find anything else.you tube vid
ah okay thanks! ill take a look at it in the morningExactly what I was going to say if you have a little trim tool though there is a little opening on the bottom right (passenger side) you can slid into and it’ll help pop it out it’s just on clips. @Jack.
It is very hard the first time to get off. But after that, I can pull it off by hand. I've taken mine off many times with no issues.ah okay thanks! ill take a look at it in the morning
In theory, this sounds very straight forward. Have you seen this done before? I'd love to jump on board and add one to mine.No, but that's my next project. Modifying that CHMSL to add the camera for cargo.
Yes, it's been done, but not on this digital version. Many have added a camera to the original CHMSL. If you look at the digital CHMSL, you can see their is a blank place for one to be added.In theory, this sounds very straight forward. Have you seen this done before? I'd love to jump on board and add one to mine.
I noticed that blank space back when I installed mine, and I assumed that would be where a cargo camera would fit in if it were offered on these trucks. I just didn't know about potential clearance issues behind that spot as far as fitment and routing goes. I didn't inspect the CHMSL closely enough to see if it was doable. Will keep it on my radar. Definitely interested in doing this with mine.Yes, it's been done, but not on this digital version. Many have added a camera to the original CHMSL. If you look at the digital CHMSL, you can see their is a blank place for one to be added.
If I'm able to do it, I'll have a write up and add it to this post.I noticed that blank space back when I installed mine, and I assumed that would be where a cargo camera would fit in if it were offered on these trucks. I just didn't know about potential clearance issues behind that spot as far as fitment and routing goes. I didn't inspect the CHMSL closely enough to see if it was doable. Will keep it on my radar. Definitely interested in doing this with mine.
Sounds great! I'll keep an eye out, would like both but will settle for one or the otherNo, but that's my next project. Modifying that CHMSL to add the camera for cargo.
Hey Toperz I'm assuming you ordered the parts in this ss as well? I got fcw and I just wanted to confirm you didn't have any issue once it was all installed.Just to make sure. If my truck has FCW then I should get mirror with that feature, right?
and is it 10' enough length of fakra cable if I have sunroof?
