theblet
- Feb 8, 2021
That's what I would suggest. Even if it take multiple tubes. The more the merrier.I put it literally across the entire inside of the top of the window.
It would be better to seal the outside, to seal the water out. If you seal the inside, it can trap the water, causing it to rust.I put it literally across the entire inside of the top of the window.
I put Permatex flowing silicone on the outside all the way across then black silicone caulk along the inside.It would be better to seal the outside, to seal the water out. If you seal the inside, it can trap the water, causing it to rust.
Cr@p I thought he did the entire outside. My bad. Yes, tape up and do the outside!It would be better to seal the outside, to seal the water out. If you seal the inside, it can trap the water, causing it to rust.
I just joined the club. Truck wouldn’t start. Jumped it and started right up but if it was off for an hour it would be dead again. 2021 Limited with 11K miles still under warranty. Dealer eventually determined I had a cracked rear window frame which allowed water infiltration which caused an electrical component to short out. They had a window company replace the rear window and ordered the replacement electronics. Had my truck for three weeks due to the part being “Backordered”. I had read about this issue on the forum and asked them to check the third brake light and shark fin antenna which they said they did but not sure they did. Not documented if they actually did check. Service Advisor told me she was pretty sure FCA was going to do an extension since they have seen quite a few of these problems. Maybe that would help those who are outside of their warranty.Cr@p I thought he did the entire outside. My bad. Yes, tape up and do the outside!
Bought my 2019 1500 Bighorn in September of 2019. All was well until summer of 2021. I started noticing a musty smell, and guess what.....mold under my floormats under the passenger rear seat. I then noticed the stained headliner and Google quickly told me that I was one of the many who had the dreaded window leak. Trip #1 to the dealer, they found nothing wrong with the window and simply replaced the 3rd brake light. 2 months later, the smell, and mold, returned. Annoyed, I took it back to the dealer. After all, I was still under warranty. This time they finally found the cracked window frame and replaced the window after having my truck for nearly 2 weeks. Fast forward to 2 weeks ago, approximately at 46,500 miles, I notice water dripping down the inside of the rear window. Sure enough, I found the leak in the upper corner, where the plastic frame meets the glass. The seal once again has failed, most likely due to flexure of the cab vs the rigidity of the window. The Permatex solution failed, so I removed what silicone I could. I'm now out of warranty and have scheduled to have my dealer charge me hundreds just to tell me what I already know; their sliding rear window is an awful design that has failed for the second time.
I'm hoping that @RamCares can help me out, or else I'm going back to a Chevy.....where I should have stayed a customer. View attachment 157548
While most people posting on forums with vehicle issues are in the minority of owners, it seems that this is a much more serious issue for Ram. The filing of a class action lawsuit is quite the indicator that this isn't just a few customers, but is affecting thousands of people who've had the problem and countless others who haven't but may in the future. If Ram is serious about maintaining their strong brand and customer base, they'll resolve this design flaw and support current owners in their resolutions.Chevy's have the rear window leak too.
Hey there,Bought my 2019 1500 Bighorn in September of 2019. All was well until summer of 2021. I started noticing a musty smell, and guess what.....mold under my floormats under the passenger rear seat. I then noticed the stained headliner and Google quickly told me that I was one of the many who had the dreaded window leak. Trip #1 to the dealer, they found nothing wrong with the window and simply replaced the 3rd brake light. 2 months later, the smell, and mold, returned. Annoyed, I took it back to the dealer. After all, I was still under warranty. This time they finally found the cracked window frame and replaced the window after having my truck for nearly 2 weeks. Fast forward to 2 weeks ago, approximately at 46,500 miles, I notice water dripping down the inside of the rear window. Sure enough, I found the leak in the upper corner, where the plastic frame meets the glass. The seal once again has failed, most likely due to flexure of the cab vs the rigidity of the window. The Permatex solution failed, so I removed what silicone I could. I'm now out of warranty and have scheduled to have my dealer charge me hundreds just to tell me what I already know; their sliding rear window is an awful design that has failed for the second time.
Nope.I'm still trying to figure out if this was fixed in the '22 production or it's still a problem on the new models.
Mine hasn't, but it's second hand, so it may have already been fixed.The question is - are there trucks that never leaked ? Hard to figure that out from the forum but it would be interesting to know what's the percentage of them that do leak and is it pretty much a certainty that you'll end up with this ********...
GM uses the same supplier so yes they have the same issue, now you can more easliy get a fixed window on the GM trucks which will avoid the issue.I disagree. I'm not a Chevy guy, but just doing a search for "Silverado rear window leaks" brings up a lot of hits. There are threads with hundreds of pages, just like there are for the Ram rear window leaks. I agree that Ram needs to address this issue, but switching to Chevy isn't going to fix your problem.
I have had 2, 1 for 3 years, the second totaled at 1 1/2 years, but neither one leaked. None of my friends with Rams have leaks. Being that there have been over a million 5th gen trucks built, and a few hundred people on here with the leak, I think more don't leak. It is a poor design though to have the leaks they do.The question is - are there trucks that never leaked ? Hard to figure that out from the forum but it would be interesting to know what's the percentage of them that do leak and is it pretty much a certainty that you'll end up with this ********...
My family has owned four 5th gen Ram 1500's. Two of those four trucks developed the cracked window frames and leaked, and two of them didn't. But the longest we kept the two without the cracks was 18 months. While on the two that did leak, it happened right at the end of the 3rd year of ownership. The prevalence of leaks on 5th gens far exceeds issues I've seen on other generation Ram forums. And one local dealership in my rural area fixes a few of these every week. I'm sure the number of trucks that don't leak is in the majority, but it's definitely an issue for more than a few hundred people out of "over a million trucks built".I have had 2, 1 for 3 years, the second totaled at 1 1/2 years, but neither one leaked. None of my friends with Rams have leaks. Being that there have been over a million 5th gen trucks built, and a few hundred people on here with the leak, I think more don't leak. It is a poor design though to have the leaks they do.
I wasn't insinuating the few hundred on here weren't the only ones.Just stating because there are a few hundred on here, doesn't mean most leak.My family has owned four 5th gen Ram 1500's. Two of those four trucks developed the cracked window frames and leaked, and two of them didn't. But the longest we kept the two without the cracks was 18 months. While on the two that did leak, it happened right at the end of the 3rd year of ownership. The prevalence of leaks on 5th gens far exceeds issues I've seen on other generation Ram forums. And one local dealership in my rural area fixes a few of these every week. I'm sure the number of trucks that don't leak is in the majority, but it's definitely an issue for more than a few hundred people out of "over a million trucks built".
