Been there done that with my cammed 4th gen. I’ll throw some stock 18s with a slick or radial on this truck and I’ll be good to go.That's when you get a 4wd and launch in 4-hi.![]()
73’ long not counting the front plow. Hahaha. She’s a big gal.you win. you have the biggest snow blower in here!
Yessir… I think they had the snow melters off that night cuz there wasn’t a ton. But the loader with the 40’ bucket plow was def goin back on the maintenance ramp.Not to mention the loaders and snow melters.
Wow - looks like a little traction would go a looong way. Looking forward to see what you can do when it hooks upI actually tried a dragy run yesterday. Traction is now a big big issue. Just spun the first 3 gears even feathering the throttle. 60ft time definitely show how bad my traction was. Going to get a tire setup for the rear and try again.
I gotta say, I probably would have drove right back to the front service desk and demanded that fixed.And now the stupid mother ******* give me the truck back with the steering wheel off-center by about 3° to the right.
Was perfectly centered when it went in. A while back some of you asked why I serviced the drive shaft myself instead of letting the dealer do it, because of sh** like this
Truck never should have come out of the alignment bay like this, zero pride in workmanship today and it's across all industries.
That's just standard suggestions for the mileage. If you are replacing stuff yourself, they don't know what you have done. Unfortunately, most owners don't do their own work, and don't have enough knowledge to understand whet some of those services are to do themselves.Took it to the dealer for an alignment.
They tried to upsale me on $1000 of bullsh**
Cabin and Air filters are washable and both have been in the last 6 months.
The diff fluid was changed 9 months ago and the brake fluid is fine and even if it's not, I have a Motive power brake bleed system and an air compressor powered fluid extractor both of which can power bleed the brakes.
And they wonder why people call them stealerships
I just looked at the service writer and said no. He then tried to explain why these were necessary to which I told him, not on a 50k mile truck
Lol, yeah, that's definitely shsdyStandard suggestions are one thing, lying and telling me that these are current problems that need to be addressed is another. The service writer stated that they inspected these items and they were in need of service.
are you keeping 5.psi in them when not in use? its requiredNot been real impressed with the Airlift 1000 bags. Starting to think part of the problem is the taller springs of the Rebel/ORG, which creates a larger volume they weren't designed for. So, working on some spacers to take up that extra inch.
One other thing I didn't like during install, and still worry about, is the bag rubbing on the axle perch sharp edge. Whether the spacers work or not, they'll at least keep the bags off the edge.View attachment 150713
