HOSE BIB 101
I know it’s not what I did to my Ram today, but you’d be using your Ram to go get parts!
Being in the insurance restoration industry, I have probably repaired 100’s of basement developments that were flooded due to hose bib failures.
Woodford Hose Bibs are designed like any ”Frost-Free” hose bib to give you the advantage of shutting the water off within the warm side of the home. The “gate” or “shut-off valve” is at the rear of the hose bib and if installed properly, allows the shaft of the hose bib to drain and not freeze.
They are widely used in cold climates and work fantastic as long as….
1 - They are installed with the proper required slope to the front shut off. If they lean back, it will trap water at the gate and that water will freeze, expand and crack the shaft within the warm side of the residence. It won’t leak till you open the valve during first use in spring. When you water your grass, you’ll be watering your basement!
2 - It’s important to remove your garden hose at the first report of frost or freezing temperatures. If you leave it connected, you negate the advantage  of the hose bib and will allow the water to freeze up and back into the hose bib and crack.
