Doc33
Just buy the smoked sequential turn signals off Amazon. And yes you have to take the whole mirror apart to replace but it's not that difficult
You happen to have a link for those turn signal from Amazon?
jl13
boyle heights, CA
Put my new 6ton jack stands to use.
Safer than what i was using before. These have a safety lock pin.
Checking and retorquing bora spacers.
As expected everything was nice and tight
Dewey
WI
Been looking to buy a new set of jack stands. Where did you buy those?
I bought some off Amazon. Was cheapest place. I bought one of the "used very good" sets to save even more.
BIG RED T46002A Torin Steel Jack Stands: Double Locking, 6 Ton (12,000 lb) Capacity, Red, 1 Pair https://a.co/d/0l8VBga
Tried to do the AJT keyfob mod. Unfortunately they AJT case doesn't work with aftermarket keyfob guts even though they look the same. The buttons on circuit board in my Ebay fob are just a hair taller than the factory ones. So when you screw the AJT case down all the way, it causes the tailgate release and remote start buttons to stay depressed. The fob doesn't like this and flashes the red LED.
Put the guts out of one of my factory fobs in it and will be the wife's key. The gray case is fairly close to my ceramic Gray paint.
jl13
boyle heights, CA
Same stands are sold at my local Fleet Farm. I was just looking at them a few days ago.
These are 3 ton. The 6 ton were right next to them.
I did look into these big red in 6ton, very similar in price and safety pins but couldn't find a store that carried them in my area and I also liked the flat base on the Daytona from harbor freight better
jl13
boyle heights, CA
color looks spot on,
I am still undecided if I want to go for that green they have for my Tank BTS
I didn't want a flat base because not all concrete is flat. If I was using them in dirt, I'd definitely want the flat base though
silverWS6
EPTX
Finally got my Vice Designs rear tow hook brackets, passenger side was installed but the driver side won't bolt on. One of the holes won't align, no matter what I do and I need to make a run to Lowes to purchase a nut.
Also painted my tow hooks, a ghetto job for now.
Quality looks good tho.
That hole looks a little out of round as well. Surprised that passed quality control.
My kit came missing hardware as well. Unfortunately, I never got to use it as it wouldn't work with the Borla tips
