crusher
- Mar 2, 2022
- Location
- st-jean quebec canada
i bet she love ridding with you :--) how old ? around 3 if i had to guess?All this rain in SoCal makes for fun times
Easier is subjective. Not everyone has the skill to get the tint film around the contours of the lens so it doesn't peelYou could buy an overlay and tint it? Easier and cheaper
YepOk, I'm assuming the module is behind the back seat somewhere? Dang that's stupid.
Yeah, she'll be 4 at the end of the month!i bet she love ridding with you :--) how old ? around 3 if i had to guess?
I did. I used a little bit of rubber cement to hold it in place...Just in case the back cover comes off. ( which it seems pretty secure.)Did you take the key ring off the physical key and store in the back of the new key fob?
Does that make it .... umhummm.... a Fram? It would be interesting ordering an air filter for it on AmazonIt's weird that your truck has a Ram rear end and a Ford front end.![]()
Just buy the smoked sequential turn signals off Amazon. And yes you have to take the whole mirror apart to replace but it's not that difficult
You happen to have a link for those turn signal from Amazon?
Been looking to buy a new set of jack stands. Where did you buy those?Put my new 6ton jack stands to use.
Safer than what i was using before. These have a safety lock pin.
Checking and retorquing bora spacers.
As expected everything was nice and tight
I bought some off Amazon. Was cheapest place. I bought one of the "used very good" sets to save even more.Been looking to buy a new set of jack stands. Where did you buy those?
Same stands are sold at my local Fleet Farm. I was just looking at them a few days ago.BIG RED T46002A Torin Steel Jack Stands: Double Locking, 6 Ton (12,000 lb) Capacity, Red, 1 Pair https://a.co/d/0l8VBga
harbor freight, around x-mas, On sale I think for $65 if I remember correctly. Regular price I think its $79 but they sent coupons from time to time. Although the discounts use to be better pre-pandemicBeen looking to buy a new set of jack stands. Where did you buy those?
I did look into these big red in 6ton, very similar in price and safety pins but couldn't find a store that carried them in my area and I also liked the flat base on the Daytona from harbor freight betterSame stands are sold at my local Fleet Farm. I was just looking at them a few days ago.
These are 3 ton. The 6 ton were right next to them.
color looks spot on,Tried to do the AJT keyfob mod. Unfortunately they AJT case doesn't work with aftermarket keyfob guts even though they look the same. The buttons on circuit board in my Ebay fob are just a hair taller than the factory ones. So when you screw the AJT case down all the way, it causes the tailgate release and remote start buttons to stay depressed. The fob doesn't like this and flashes the red LED.
Put the guts out of one of my factory fobs in it and will be the wife's key. The gray case is fairly close to my ceramic Gray paint.
I didn't want a flat base because not all concrete is flat. If I was using them in dirt, I'd definitely want the flat base thoughI did look into these big red in 6ton, very similar in price and safety pins but couldn't find a store that carried them in my area and I also liked the flat base on the Daytona from harbor freight better
That hole looks a little out of round as well. Surprised that passed quality control.Finally got my Vice Designs rear tow hook brackets, passenger side was installed but the driver side won't bolt on. One of the holes won't align, no matter what I do and I need to make a run to Lowes to purchase a nut.
Also painted my tow hooks, a ghetto job for now.
Quality looks good tho.
