My Maxtrac lowering installation
ferraiolo1
North Central PA
Got back from a 500 mile trip to the beach. Bike weighs around 500lbs. Me, wife, two hound dogs, coolers, riding gear, and luggage. Bags as 30psi. Did pretty well.
U
User_67930
Guest
That Indian is beautiful.
ferraiolo1
North Central PA
Not too shabby. Wish I could take both of them. But that puts me over my payload. My Silverado didn’t care since it was lifted.
vincentw56
Now that they have the control arms, I'm going to start getting the parts together.
ferraiolo1
North Central PA
I was going to buy them and lower it a bit more. But after looking at my cv angles and no tire wear after 6k miles. I’m going to leave it alone
vincentw56
My concern is the ball joints. I lowered my Dakota and I had to replace the ball joints every two years. That could have been just a thing with the Dakota but that makes me worried.
vincentw56
How's the ride quality been? Stock rides really well. I'd like to keep it as close as possible. I know it will be a little stiffer, just don't want it to be a lot stiffer.
AWAKEN
North Mississippi
I haven't found a detailed thread with all the P/Ns and info in one easy to find post. Here ill post all the P/Ns, specs and links for the parts im installing. Most of this info is thanks to @Mopar_maxi
Truck is a 2021 Laramie Sport, CC, short bed, 4x4,non ORP, with etorque.
Suspension-
Mactrac 2/4 in lowering kit - P/N K332724
AIR LIFT 1000 Series Rear Airbags designed for a Durango- P/N 60824.
Spohn Performance Adjustable Rear Panhard Bar- P/N D09-1500-104 (you can get red or black)
Rear Bilstein 5100 shocks from a early 90s ford ranger. P/N 24-185684, ASIN # B004WO9JK2
With the spohn panhard you do not use the maxtrac relocation bracket, nor do you use the sway bar spacers in the kit. For the 5100 shocks you swap the maxtrac shock sleeves into them.
Wheels and tires-
Vossen HF6-1 22x9.5 +20- P/N HF61-2G20 with their Vossen lugs in black
Kumho Ecsta STX KL12 305/45R22- P/N KUM-1649113
As my truck sits right now with the 2in drop springs in the rear, I'm at 36in F and 37in R. My plan is to set the front struts to 1.5in, which should give me close to to no rake, and help keep the front alignment in the green. And use the helper bags when I load the motorcycles in the bed. Since every 2/4in dropped truck ive seen still has rake.
So far im right around $5k for everything since I was able to find a few deals and discounts. Pictures and video to come as I start everything based on the weather and snow on the ground.
An overview vid​
AWAKEN
North Mississippi
Have you heard of or found any lowering "kit" or parts that work better than what you currently have? BTW (Love the look)
chad202
I lowered mine 1/2.5. Adjustable struts up front and removed coils in the rear and replaced with Firestone air bags. Ride is better than before and now can pull my boat without it squatting. Just add 20lbs to each back and level. Love this setup.
ferraiolo1
North Central PA
Here are some pics with the 1.25in spacers and vossens. Still no rub with the liner tip tied back. These wheels have pretty large cutouts in them. You could get away with .75in spacers and stock studs
