Rick3478
NW OH
I have a 2020 with 33k and the strips have been on since the factory. From as far as I can tell, my fat a$$ trying to get under as far as I can see, I don't have anything unusual going on at the moment. I've also never done anything to the exhaust, all stock from tip to tail. I also pull a 37 foot travel trailer with mine, if this in any way helps your theory.
(y)I tend to be a fan of whatever works. If it doesn't make weird noises or have pieces falling off, I'll probably leave it alone.
Eighty
Moderator / Dream Killer
I haven't dived deep into the root cause of these problems, so I've got a question. Is it because of expansion/contraction due to heat, or is it the galvanic reaction between dissimilar metals? The picture above showing a rusty bolt would lead me to believe it's a galvanic reaction issue.
Rick3478
NW OH
My 2020 has them, this is the passenger side. Build date of Oct 19
But it looks like you also have a bolt on the end of the manifold that isn't through the strips. Was this an intermediate step in the design evolution? I dunno, getting more curious, gonna have to take a closer look at my own.
BowDown
Frisco TX
I don't know but I've pulled enough exhaust manifolds to know that a driver side a passenger side may have different bolts in different places. The passenger side was easiest for me to see.
The guy I quoted looks like either a manifold revision or his pic is the driver side as he doesn't have the center bolt on the end that I do.
Mine has the upper lower and the outer where his just appears to have the upper and lower so, I don't know
Rick3478
NW OH
Thermal I think. Galvanic I would expect to see where the metals meet, not over the entire surface.
Grape_Ape
It's happened to both of mine. Seems to be hit or miss on whether it happens or not. 2020 with 36,xxx miles. Replaced the passenger side under warranty and I need to go back in for the drivers side. Just don't feel like dealing with the service dept.
crusher
st-jean quebec canada
and did yours had the strips?
Rick3478
NW OH
MIne did not crack but I put shorty headers on under 10K miles because I got a great deal on them and all the talk about cracking manifolds.
I was wondering if the shorty headers might have their own unique problems, what with short welded tubes pulling on flanges at weird angles. Do you have any thoughts on that?
BowDown
Frisco TX
Headers in general need to be re-tightened/retorqued every so many thousand miles.
Some loctite the bolts, I didn't on my car, just check them every 10k or so
397STROKER
I have not had any issues so far. I got the AFE shorty headers. I had shorty headers on my 97 ram and never had a problem.
Belvedere
My passenger side manifold has that lone bolt in the front. I just assumed it wasn't in line, so no strip.
I've run headers on many vehicles without issue. I can't remember ever having anything with manifold flanges this thick though, or so many reported cases of broken bolts and cracks.
My feeling is the bending moment/fatigue of a long bolt through a thick flange, regardless of any tricks they employ. It's likely both manifold and bolts are similar steels, so galvanic corrosion is unlikely.
However, that does bring up a good question. Where are they breaking? Near the head of the bolt? Flush with the cylinder head? Somewhere in between? Just bolts breaking, not studs? Not sure how many of each there are.
Sounds like there are still issues with the strips, and ill probably go with shorties.
RAMonkey
Davie, FL
I put this dash cover on from Covercraft. It seems well made, but I gotta sit with it for a while. I’m getting a late 70s Cadillac vibe…
RAMonkey
Davie, FL
I'll hold my tongue on the dash cover. But I have to say, I LOVE the "Fire Missiles" button on your cigarette lighter outlet.
Thanks. I’m waiting for my son to discover it!. Now, do I let my wife set her eyes on the dash cover. That’s the real question…
