wacopolumbo
Thanks for your kind words. I really like the grill too. No worries about the lights. They are just barely too wide to fit. A little Dremel work in each hole would make them fit the hole, but I don’t think the screw holes line up either. If I didn’t physically try to put them in, I would have sworn they would have fit too. But hey, they were only $20. It was worth it to see if they would work.Looks freaking sweet on your truck. The amber is growing on me too. I haven't tried to install those lights yet. I haven't even taken them out of the shipping package yet.I don't think I'm brave enough either to cut up the grille to make them fit. I apologize for them not working. I didn't even notice they were a different size. The one issue I ran into with the letters is the mounting tape wasn't the greatest on one of the letters so I wound up getting some 3M tape from AutoZone to replace it. What did you wind up taping into for the lights? I wound up running the ground to one of the factory grounding points and the power to the positive side of the fuse for the trailer running lights. That way it's removable just in case anything happens anyways.
Sent from my SM-A536U1 using Tapatalk
After I put several clear coats on the letters and let them dry good. I mounted them with the tape and let them sit over night. They seem like they are on pretty secure. I crossed my fingers yesterday when I took it to my car wash that they would still be on when I came out the other side and all was fine. It’s not a bad grill. Definitely not as robust as the factory grill though. But I think it will last. If it doesn’t, I can try another one without the letters and and lights or go back to factory.
For the lights, I used a fuse tap and went into fuse 60 in the engine bay fuse panel. RAM Patriot recommended that in another thread. That fuse comes on with the truck ignition in the “run” position so it works perfect to have the lights come on with my DRLs. Also easy to remove. Just pull the tap and put the fuse back in.
