Post your lowered 5th gens
Clv22p
Nashville, TN
Like the title says. I want to see everyone’s lowered 5th gens.
Post a picture and a description of your setup!
Maxtrac 2/4
Bilstein 5100 rear shocks
Spohn adjustable panhard bar
Hellwig sway bar and end links
Core 4x4 rear lower control arms
What rear swaybar end links are you running? If Helwig do you have the part number?
ferraiolo1
North Central PA
MLB12
Calgary, Alberta Canada
So I see what the 3/5 swap looks like, and this is where I'd like to go.
In looking at that particular swap it is obviously doable on the 4 x 4 DTs, but I can't see, or may have missed it, but has anyone done a lowering swap on a 4-corner factory air ride truck? And if so, been able to retain all the features of the air ride?
All input will be appreciated.
Rock Crawler
Lone Star State
Might check here.
1LowTrk
How are you alignment specs when it’s low?
Not sure, feels straight when driving. Today, the truck only has 1,000 miles! Haven’t needed to touched the suspension besides adding the revel links and cutting out the bump stops. On Monday, I’m gonna follow your advise and I’m gonna pull the trigger on some new rear shocks. I’m going with QA1 TD902’s and see if that helps lower the rear inline with the front. At that point, I’ll obviously get a alignment. I’ll snap a pic of the screen when completed.
