Why new springs in the back, did you still need the Spacer then?Rough Country 3.5” Strut lift with N3 rear shocks, Icon 1.5” lift rear coils, Wildpeak AT3W LT275 65r20. View attachment 131718View attachment 131719View attachment 131720View attachment 131721
Spacers not needed with the springs as they are 1.5“ lift. Prefer to use coils or springs rather than spacers. Much better ride. May end up adding a spacer to the rear driver side due to the weight of a full Gas tank dropping the rear driver side an inch. Waiting for the new springs and coils to settle first.Why new springs in the back, did you still need the Spacer then?
Jared B., great look on the truck. I have exactly the same and was wondering if those size tires will fit without the leveling kit or if they'll rub...295/60/20 Nittos and Rough Country's soon to be released leveling kit.
Looks good!2022 Laramie Southwest Edition
Readylift 3.5 without preload spacer, Bilstein 6112 clip 5, 5160's in rear, Ridge Grappler 295/65R20.
No tire rubbing so far.
6” BDS makes Rocco look small
No didn’t do anything to the tow hooks. Totally stock 21 rebelI've never seen tow hook bezels like that. Are those aftermarket?
Nice ride!6" BDS on a Built to Serve (1" raised right height), 20x10 Fuel Vector with -18 offset and Falken 35x12.50r20 load E. Stance is great, ride is fantastic.
View attachment 135870View attachment 135871View attachment 135872View attachment 135873
Bds is the way to go!!!6" BDS on a Built to Serve (1" raised right height), 20x10 Fuel Vector with -18 offset and Falken 35x12.50r20 load E. Stance is great, ride is fantastic.
I had a 2021 Laramie with a 6" Fabtech with the same size wheels and tires. It was really nice too, no complaints with quality. The turning radius on the Fabtech sucked and it had a rear spacer where BDS replaces the entire rear spring. BDS rides a little nicer, but if you only own one you would be happy with the Fabtech, I was. This is my 2nd BDS 6" on a Ram. Had one on a 2013 as well. Good stuff!Bds is the way to go!!!
Never knew the blue one was yours! Came across that one on here and FB several times and was always a little jealous lol. Super clean! Love your current setup as well (obviously)! There is just something about that blue though.I had a 2021 Laramie with a 6" Fabtech with the same size wheels and tires. It was really nice too, no complaints with quality. The turning radius on the Fabtech sucked and it had a rear spacer where BDS replaces the entire rear spring. BDS rides a little nicer, but if you only own one you would be happy with the Fabtech, I was. This is my 2nd BDS 6" on a Ram. Had one on a 2013 as well. Good stuff!
Ha yep! The blue was definitely photogenic. I did love it, wish I still had it so I sort of recreated it. I bought the blue one from the dealer, they had built it for a car show to showcase their shop. The black one I picked everything out and had that same dealer do all the work. Worked out great!Never knew the blue one was yours! Came across that one on here and FB several times and was always a little jealous lol. Super clean! Love your current setup as well (obviously)! There is just something about that blue though.
So you only have the 2” spacer that goes on top of the strut in the front and the UCA’s from the ReadyLift kit and the Bilstein’s on clip #5 are 1.7” (non off-road) I think? So 3.7” total? I bought the 2” ReadyLift leveling kit with the UCA’s and was going to put that on now. Then when I am ready to buy bigger tires and new wheels I was going to add the bilstein’s. My truck is a 2 wheel drive crew cab with the 6.5’ bed and the darn thing looks like a low rider right now! And with a 1/4 tank of gas my front end sits 1/16” shy of 3” lower than the rear so I figured throwing the 2” level on the front will help a little.2022 Laramie Southwest Edition
