Nels
Wisconsin
This with all 4 doors and the tailgate open. The icon shows the open doors but not the tailgate. Doesn't change when shifting from park to reverse or drive.
Clv22p
Nashville, TN
Changed the oil. I hate it.
To all of you that say "I never spill a drop", I call BS.
I changed the oil too. Literally didn’t spill a drop! I used a quart sized ziploc for the oil filter
For whatever reason this was the smoothest the oil change had ever gone.
I installed a Fumoto oil drain valve this time so hopefully next time is even easier.
shaginwagon
Finally installed my new suspension bits…
i had the org stuff on my north edition truck…
lowered the back 3 inches and the front 2 inches.
edit…
the darker one is morning pre work and
the sunny pic is afternoon after lowering.
Who's lowering kit did you use? Part # ?
silverWS6
EPTX
Lies, lies, lies! Lol I tried the ziplock bag trick and somehow the oil made it out and then the filter tipped and the mess began.
Idahoktm
North Idaho
that dash is level 2 and b for some trucks
just trying to point put that not every truck will have the ability to show the tailgate open
I believe some of the trucks came without tailgate open sensors, so even if the feature is activated it won't show up.
Nels
Wisconsin
This is from my window sticker. Level 1, Tailgate Ajar warning listed. Presumably it has the ability to show it, yet it does not. I am assuming a dealer should have the ability to turn it on?
MidnightExpre$$
New Jersey
Didn't really do anything to the Ram, but was at Tractor Supply and purchased a mini ram. They didn't have a 1500, but not many people will pick out the difference of this 3500 when it is hanging on the Christmas tree - at least it is the correct color to match my truck. . . .
grimreefer
U.S. Merchant Marine
Free State of Florida
I believe this is indicating that your tailgate is open. Could be wrong, though.
grimreefer
Also... don't know if it makes a difference, but did you try it with the doors closed and in Drive?
grimreefer
My 2020 Built to Serve didn't even have that indicator until I enabled the tailgate ajar warning with alfaOBD
Now that I look at that pic again it doesn't have the little bar on the bottom so... I dunno. It should have at least that little indicator as per his window sticker.
blckout
Gave her a bath
Lpsouth1978
You would think so, however, based on other threads on the subject, The dealer is NOT likely to turn it on for you. It seems that Stelantis has chosen to only activate it when specific (and unrelated) options are purchased. Last I have seen, no one has been able to get it activated at a dealer, though there may be a rare instance I am not aware of. I activated mine (Laramie Level A) with AlfaOBD, but also used it to change tire size, switch DRL location, and a couple other things. Worth the cost in my opinion.
Duran
Video challenge lol
