I think you may be right.
I just installed mine at clip 5 and it's a little over 3". I wanted to keep some rake for when I tow.
How are you liking the ride? My initial ride report is woohoo........ better than the fox ride.
Wrote the check for property tax💸. I hope they use the money responsibly
Had the recall for the back up camera and e-torque done yesterday. Hadn't had any issues with the e-torque, but a couple of times the back up camera wouldn't come on.
Installed Tiger Tough front seat covers. Why...because concerned I will wear through leather bolster on drivers seat. Had to replace it once already for this issue. Was covered by Warranty after so push and shove with FCA. Good dealer support helped. Like the seat covers. Fit extremely well. Two negatives, however, they don’t make covers specific for Limited rear seats and they don’t make a console cover at this time. I have talked to manufacturer and hope this will change in the future. Compared to other major manufacturer of precision cut seat covers of this type, they are well priced.View attachment 32608
@duke2001 I'm with TigerTough and wanted to let you know the rear seat cover for the Limited has just got out of R&D and will be on the website shortly. Sorry, it took us so long to get that one! Since we focus on work trucks we're not always the fastest on the high-end trim level trucks like yours.
I think it rides pretty nice. Hard to compare to factory because I installed Ridge Grapplers at the same time. Load range E tires ride a bit firmer than the factory tires, of course, even with 40psi.
Do you have a measurement from center hub to fender with your 6112's on clip 6? Also, did you lift the rear as well?
Post a side photo if you can, I'd like to see how it looks.
I had my zone 4" lift and 22x10 -18 fuel flame wheels with 35x12.50 kenda klever rt installed. Also had them install the bedstep
That wheel color looks nice against the color of your Rebel. :cool:
You just showed everyone that you are old . . . .
I’m definitely “older” but way wiser!
My system has worked flawlessly for about 18 years.
Total cost of my garage wall sensor? About $0.26 CAD. That’s about $0.19 USD.
Some things just don’t need improving upon. 😎
Yes I have a 2" lift in the rear. I also replaced the rear fox shocks with 5100s. I like the ride much better than my Mopar lift so far, bilsteins eat up bumps much better.
Measurements from center hub:
PF 25 3/4
PR 25 3/4
DF 25 1/4
DR 25 1/2
Made a stop at the WAAM museum in Hood River, OR. No more saggy truck thanks to the new airbags. Also drives much better!2CA66183-BFEE-4D43-A93C-77E276CB5012.jpeg
2930fc2e-8dad-43e8-ac67-4793afd17113-jpeg.134154
  • Bt10
