Clv22p
You don’t have shocks in the front. They are struts. If your doing Belltech spindles there is no reason to change them. If you have to have bilstein in the front you could do a 5100 (used for lifting the front usually) set to stock ride height. Or you could run Belltechs coil over set to stock height.Gotcha. I’ll place an order. I’m currently searching for the matching shocks for the front.
