Dmalonecentral
- Aug 19, 2018
Ran into this exact problem today here in Memphis. I think it's a skrillion degrees outside and my USBs are definitely not working today.
This was my response from FCA. I emailed her back less than 10 minutes after she sent this and no follow up.
Hi, I just wanted to advise you that I have gotten a response from my internal tech team. I have a few more questions for you. They want to confirm if your able to play media from other sources, like a USB connected to the media hub, when you feel the heat is preventing Carplay from functioning. You might be able to alleviate the issue by running the hvac to cool the cabin temp to prevent the issue if you believe that is occurring (the resister tripping and not resetting until it is cooler) if this is actually the root cause of the concern. Thanks Tiffanie.
