I don’t think it’s tied to the radios temp sensor either, from my findings. It didn’t work at 93, but worked at 96 after I turned the truck off for 10 min.
Yeah that sounds right. I forgot the hub stayed on for a while after the truck is off. From the sounds of it, I wouldn't be surprised if that power down was 30 minutes.
So you'd need a 30 minute reset after you get the temp down? That sucks.
I find the same thing, but o don’t have to power down for 30 min. 10 min usually does it @RamCares hasn't responded yet
Thanks for this. Do it looks like if you bypass the hub, you would only get power. I wish someone would actually tell us what the technical explanation is, what are the thresholds, and what values allow it to function again.@theblet Since you are experiencing the same issue I had another thread going asking if it was possible to bypass the media hub and go directly to the head unit for CarPlay. According to one guy you cannot but I noted some observations over there if you want to take a look. I am now determined to figure this out because it absolutely ridiculous that we can’t use this feature in the summer.
Bypass Media Hub (Fixed Link, I think)
Bypass Media Hub
I was looking online and it appears the connectors on the back of the Media Hub are standard Mini USB-B connectors. Does anyone know if it’s possible to just bypass the media hub and plug directly into the Head Unit for CarPlay since the media hub quits working when sitting in temps more than...5thgenrams.com
I'm not experiencing this problem but this seems like a simple enough request..... I wish someone would actually tell us what the technical explanation is, what are the thresholds, and what values allow it to function again.
Weird, I also live in Phoenix and I have never had this issue. My RAM is parked outside everyday and temps inside the truck get VERY hot.
This makes me think there is a bad batch of resistors in the media hubs.
I see you have 2021. Mine is a 2019. They could have fixed it in the later versions.
Interesting. I wish we know what the threshold is. Was there a redesign on this hub that would fix the problem? I am expecting a call from FCA, and will let you know what they say.Just want to add that not sure exactly what causes the power to come back to the media hub during the course of normal driving when the cabin temp and ultimately the temp of the thermistor come back down to safe operating temps but can confirm that pulling the F44 fuse and putting it back in did work immediately for me. Temp was in the 110-112 range today. Auto started the truck about 10 minutes before we left, drove about 5 miles. CarPlay not working this whole time. Got to our destination and pulled the fuse for a few seconds and reinserted and BAM, CarPlay started working immediately. This isn’t going to help much if you are driving as you have to pull the panel below the steering wheel to access the fuse and it’s hard to get to even after you do that but I think it’s worth noting that manually cutting power and turning it back on will bring CarPlay back if the temp is below whatever threshold the Thermistor can handle. I am considering adding a Toggle switch to that fuse location to be able to do this while driving. Also note that this fuse also powers the OBD port and the CD player.
On another note, anyone know how to replace it or get it out? What if the thermistor is replaced with a regular resistor?
