- Jul 25, 2020
Yeah, just have to have parking lights onHas anyone been able to turn the fogs on anytime ? Without low or high beam on?
Fog Light Dropout With Highbeams DisableHas anyone been able to turn the fogs on anytime ? Without low or high beam on?
Ok so turn the parking lights to always on?Yeah, just have to have parking lights on
I did this and keeps fogs on with high beams. The question is more how to it sounds like make parking lights on when truck is turned onFog Light Dropout With Highbeams Disable
CBC Features: Front Fog Lamp Dropout Enabled-no
If you want to have fog lights on without turning the headlights on, you have to turn your headlight knob to parking lights. There is no setting to make them always on.Ok so turn the parking lights to always on?
Do you know what setting that is?
Ok thanks for that.If you want to have fog lights on without turning the headlights on, you have to turn your headlight knob to parking lights. There is no setting to make them always on.
Never mind, found this issue. The instructions from years ago said to choose "Central Gateway Module" but that looks like it is for old models. Used the "DT MY2022 PowerNet" and all worked great.getting the error “Failure to verify connected control unit”
CBC Features: Aux Switches PTO- Six SwitchesDoes anyone know the settings to turn on the aux switch panel for the 1500s? I’m told to get the auxs to work need to turn that option on. Any ideas? Sorry for all the questions but this thread set is a wealth of knowledge so thank you for everything y’all have helped with .
Thanks. have a 2021 ram 1500. I haven’t gotten the switches yet as the panel I have been looking for, getting the part number is extremely hard. I saw the kit mopar has but I want a specific version of the switch.CBC Features: Aux Switches PTO- Six Switches
Lin & Misc: ASBM Present- Yes
CustSetMenu 1: Auxiliary Switches CSM Present- Switch 3-6 option
The aux switch settings will only work on 2021+ 1500’s
I have a 2022 I don’t have the switches either, do you have a link to more information about this mod I am looking to add accessories but would love the factory switchesThanks. have a 2021 ram 1500. I haven’t gotten the switches yet as the panel I have been looking for, getting the part number is extremely hard. I saw the kit mopar has but I want a specific version of the switch.
Yes but need that part number. For that exact switch. Anyone have that part number?I think you’re looking for the Upfitter switches https://www.ramtrucks.com/BodyBuilder/service/Image?imageId=MtQrP/FqLY5r/est8MtGjGgHzAHGUTU0WB3rWuqSY7YmQ2vEhuBWBAX0kF8xQ1nk
Considering those are for the fourth gen cab trucks, you would have to fabricate some way to make them fit in a 5th gen 1500Yes but need that part number. For that exact switch. Anyone have that part number?
The part number for the switches you see in that body builders document is 68376640AE. It’ll fit and work in your 2021 1500.Yes but need that part number. For that exact switch. Anyone have that part number?
This is a 5th gen switch set. The 4th gens are different.Considering those are for the fourth gen cab trucks, you would have to fabricate some way to make them fit in a 5th gen 1500
Hey jimmy. I see mine is traction control then tow haul and not tow haul and traction control. Wonder if this is going to cause an issue.The part number for the switches you see in that body builders document is 68376640AE. It’ll fit and work in your 2021 1500.
