JamRam
TyH2009
St. Louis
GraniteRam
Sir, thanks for this post and link , I've ordered this as well. Question-how did you wire the lights? Did you need a kit? Tapped a certain fuse I assume?
If you ordered the grille for the Rebel in your signature, it's not going to fit. Ebay description says it doesn't fit Rebel, Longhorn, and Limited.
cleandirt
I picked up a Diamondback SE cover from the shipping terminal this afternoon. I don’t have it completely installed yet, I’ll finish when the sun isn’t directly overhead baking my brain. I found the cover on Diamondback’s discounted outlet site as a mis-ordered return, I think I’m going to be a happy costumer.
U
User_63152
Guest
I love them!
Here is the link.
I will not I replaced the leds that it comes with with some better ones.
Are the LED's in the grill crap? Or, you just wanted better ones? If so, which LED's?
JustCallMeD
Ontario
Just got it cleaned up since summer finally got up here.
E36D9F21-AE89-469B-88A6-62B1C32D8D22.jpeg AD59DF80-7EC7-452C-BF82-068A18F43C63.jpeg
Also, Air design spoiler, Weathertech vwindow visors, Fuel Platinum bronze wheels with new rubber, Lund Elite series flares (Removed OEM flares), 3M wrapped the chrome trim and just finished doing some emblem painting to try and match the wheels but no pics for that yet...
Ccroce
Holliston
Installed the Bilstein B12 1 inch rear coil springs and ORG rear shocks to match. Stripped a lug nut stem because I was being an impatient dumbass putting one of the wheels back on, but otherwise a relatively smooth install. Definitely recommend a pry bar and spring compressors.
Tankbrt
The grill comes with a harness. I tied in to my side amber lights with a wire tap. The lights only pulled 1/3 of an amp on my meter so I'm not concerned about popping a fuse.
Tankbrt
I wanted smoked leds. I just found some that looked close on Amazon and they were about the same quality I got these
4 Grill Lights Fit for F150 2004-2020 Raptor-Style Aftermarket Grille Replacement LED Grille Lights Lamps(Smoked Lens with Amber Light) https://www.amazon.com/dp/B09J21B33W/ref=cm_sw_r_apan_i_CTZ5994C6GX62E68V4X7?_encoding=UTF8&psc=1
I know it says it's for the raptor but they are the exact same ones that come with the grill.
Snicklefritz_76
NJ
How do you like the Recon Grapplers? I’ve been looking at them but in a 305/45/22.
Looking at them on my truck gives me an ear-to-ear smile, just on the inside though, I try to keep a sullen persona on he outside.
I'll be putting some miles on them this weekend. So far, ride is a little more 'truck feeling' but no noticeable road noise. The front rubs so I will have to fix that but overall I'm loving these tires.
djevox
VP of Creative Thinking
MD
So much for trying to get here early for a quick oil change 🤣
Been in line for 20 mins already 🤦🏻.
At least you get to look at the pretty palm trees.
